Buck 301 Stockman vs Schrade 80T Stockman
jefroman
Which do you guys think is the better choice? I like the Buck because of the black handle scales and the stainless steel. But I like the Old Timer because of the carbon steel and the flat grind.
Thanks!
Jeff
I like them both, but for an everyday carry with low maintenance I prefer the Buck (actually I have a 303).
I also think that, while the Old Timer is a great knife, it does'nt have quite the fit and "attention to detail" that the Buck has. The flat-grind is a little better but does'nt make much difference to me in everyday tasks.
You can't go wrong with either one.
Good Luck,
Allen.
jefroman:
Since you live in a dry climate, I'd go with the carbon steel Old Timer. I live by the ocean, where there's a lot of salt in the air, so I generally prefer a stainless blade. Both are great knives for the money.
My grandpa carried a Buck 301. My Dad carries a Buck 301. I occasionally cary a Buck 301. I can't speak for the old timer, but the Buck is a great pocket knife.
That's a tough choice. Both of these slip joints are very good. I guess it all depends on what you are looking for most in terms of quality. Here are the strong and weak points of both knives, IMHO.
Buck:
1. Good stainless steel blades
2. Come very sharp right out of the box
3. Good looking Delrin handles
4. Very distinctive hollow grind for a slip joint
5. Blades all run parallel to each other
6. Each blade has its own back spring
7. Acceptable, but not great “walk and talk”
Old Timer:
1. Excellent carbon steel blades
2. Excellent “walk and talk”
3. Good standard flat grind
4. Ugly Delrin handles
5. The larger models are a bit bulky in the pocket
6. Come duller than dirt
What it really comes down to is priority. The old Timer isn’t pretty, but it’s built like a brick sh*thouse. You need to be careful in selecting your Old Timer. I’ve seen lots of them at Wal-Mart with very badly ground tips on their blades. The Bucks have much better quality control. Better than most any slip joint manufacturer, as a matter of fact. The Buck is the consistent, good overall quality knife with good form and function. The Old Timer is all about function.
Personally, I'd prefer to spend the extra few bucks and get the wood-handled Buck 701 instead of the Delrin 301. I checked at one internet knife shop, and the difference is just $12. No matter, though, they're both priced right when you consider Buck's customer service and the fact that they'll last a lifetime.
I've had the 301 for years and it has survived just about everything but nuclear attack. Still looks pretty good, too.
I have knives from both Buck and Schrade and my preference is overwhelmingly for the Buck. When I was younger in the 1970s it seemed like the Schrades had better quality control and came sharper out of box, better fit/finish than today (that I've noticed, anyway). Schrade does make a good rugged knife, though. The Schrade carbon steel seems to me to rust if you look at it funny.
I like the fit and feel of the Bucks better. Whether you pick a Buck from the 300 series or the 700 series. The 301 seems to have a bit less walk and talk snap to the blades than do the smaller Buck pocketknives. My 301 is one of the older flat ground versions with mirror-polished blades, but now they are all hollow-ground, which I like better and is unusual on a slip-joint pocketknife.
I've never had to use the Buck warranty service, but if I ever did, I live not too far from the Buck plant anyway.
Jim
I have the 303 and the 108 ot. The Buck takes a better edge with the edge 2000. I carried the 108 for about 5 years.
guy
