I have a 1987 Buck 309 that I was told here at Blade Forums uses 425M stainless steel. I've had trouble getting it as sharp as my 1979 Case 62042 SS or my 2014 309 and the 1987 309 won't hold an edge even though I only use it at work to open envelopes mostly and occasionally to open small cardboard boxes and cut string/twine.
I use the same sharpening method as I use on the other two knives (and many others with different steels), which is Sharpmaker at 30 degrees compound (only once so far for both 309's since they're both new to me and about once every few years or so for the 62042) and stropping on an old leather belt with Flitz every so often throughout the year.
Because of the trouble I've had with the 1987 309 someone here suggested the 40 degree compound micro-bevel option on the Sharpmaker and that seemed to get better results, but then I still have the problem that it won't hold an edge even with ultra-light office duty that the other two knives handle with ease.
I found a thread here from around June 2005 about Buck's 425M and 420HC and a guy named Joe Houser, Director of Consumer Relations for Buck Knives, said the following:
"They can both be sharpened the same way and unless you have an older knife with a different edge geometry, ease of sharpening should be identical."
Questions:
1. Does my 1987 309 fit into Mr. Houser's definition of "an older knife with a different edge geometry"?
2. If it does fit the definition, does he mean it'll just be harder to sharpen using the same methods or does a different sharpening method have to be used?
3. If it doesn't fit the definition, can anyone point me in the right direction as to what I might be doing wrong?
Again, I have no trouble whatsoever using my sharpening method on Case Tru-Sharp or Buck 420HC, only on this one 309 made out of 425M.
Questions:
