- Nov 5, 2012
I saw the threads where you all were noting the differences & changes in the 300 series, changes in manufacturers, etc, and was wondering about some 500 series differences. I just received my older 503 that I got for cheap, and was comparing it to my newer 2002 model. At first I thought the blade looked way short when looking from the top view, but now I see the difference. Maybe if someone has a newer and older one, you can make this comparison also, and confirm.
First off, is this micarta on the older one? From a distance, it looks like wood grain pattern, but up close, it has the woven linen look.
The exact measurements of the blades when open are a full 2- 1/4" on the older, and 2- 5/16" on the newer. I think these are advertised as 2 - 1/4 blade length. Seems the older one is a little less pointy, and of course more worn, but still there.
After looking closer, I noticed that the whole bolster at the pivot end is different on the older one. Shorter distance from point A to B, which makes the line from B to C at a completely different slope / angle. Seems that a slight difference in the geometry of the blade joint makes it look shorter when closed.
I just wondered if you guys noted these differences, and if they indicate any certain manufacturer or time period. I like replacing my newer Bucks with older ones. This one should polish up and sharpen up pretty well.
JT
........... here are the pics. I know, I was having fun with the arrows.
JT
