Saturday I had just received my Buck 661 Pursuit lockback and I like lightweight lockbacks so I have to admit this felt really good in the hand. I have to admit though I'm not digging the spring bar they use from a few observances as a design I've never seen before...
*This design seems to be a thinner, tapering bar that's held in place by nesting into the plastic scales. So no this isn't a post design fitted into the metal spacer...this seats in front of the metal spacer held up by plastic.
*A bit of vertical blade play when I bare down to cut. I can grab the blade spine and feel that small degree of vertical movement.
Now I have an old 450 Protégé and a 442 Bucklite that use the cylindrical post found in the 110/112 models and are rock solid/no play. I noticed this similar problem when the 722 Spitfire came out from a thin spring bar design and blade play it created. This is the kind of flaw you feel on a $10 gas station knife. I just don't understand the cheap spring-bar approach. I'm definitely concerned the Pursuit's spring bar will slip out of one of the plastic notches it seat in from wear or stress.
This knife was definitely not worth the $50.
