- Jun 8, 2014
Is there any way to tighten up the pivot on bantam 285?
Thanks
Thanks
Thanks
ZTD, the title of your post and the body of your refer to two different things.
If you are interested in tightening up the pivot pin to eliminate/reduce side-to-side blade play, here is my video on tightening pivot pins:
[video=youtube;ySqwxPmF4-k]https://www.youtube.com/watch?v=ySqwxPmF4-k[/video]
If you want to adjust the lock up of the back lock on your 285, I defer to more knowledgeable members of this forum.
First thing I would do is to clean the lock tab and notch really well. To see if they will seat better, and therefore lock up tighter.
I've done that it helped a lil but it still has a problem.
Also, examine the blade pivot and the lockbar pivot.
Specifically check to see if the pivots are moving up and down in their holes, when you test for blade play.
If your lock is failing, I would send it back to Buck, or just get a new one.
