Buck Blade Heat Tolerance
Ya know, we've all seen it in the flicks...some hombre puts a blade in the campfire coals and brands something (or someone).
Well, I was wondering, what do you steel experts think the max temp is for a Buck blade before you mess up it's molecular structure?
Boiling water is 212F degrees (just a reference).
Certainly, there are differences with various steels, but I was just wondering in general in case I need to roast marshmallows with my 651 Pig Sticker, or poke at something boiling in stew with my 110, or brand "something" ;)
Thanks in advance for your replies...
Hey Goose - Just to play it safe, I'd use the pigsticker to make a nice sharp point on the end of a stick and then use that for the marshmallows or weiners. I think it would be ok to stir the stew, but personally I'd use a wooden spoon. :o
Later,
Mike
I've cut pot roasts, turkeys and other meals that come out of the oven at over 400F with all types of blades. No adverse affects so far.
I don't think you need to worry about 212F.
Judging from the Latrobe steel data sheet for 420HC, I'd say anything over 200 degrees will begin to run the risk of hardness loss. There is a time factor in there too, tempering times usually run in the hours scale, so momentary contact with boiling water shouldn't be a worry. Flipping coals in the fire is definitely out though imo.
Latrobe 420HC data
The oven might have been 400, but the roast wasn't (unless it was a cinder :eek:). Beef is well done at an internal temp of 170 degrees F or so.
:foot: That did sound completely wrong, didn't it?
Internal temp would be much lower. Surface temp could be higher. I just meant 212F was nothing to worry about.
But I think using the knife as a marshmallow skewer is out of the question! :eek:
Yeah, I am usually good about keeping my blade out of the coals/flame.
Remember as a young Scout I would see other guys poking their knives in the fire or laying them in the coals to go burn their initials or something in some wood. Even then I thought that was messed up to do that to a knife.
I think 200F would be a good rule of thumb...but I have been known to use a 110 to stir up some Dinty Moore or Beenie Weenies.
Mike's right..."use a different tool Goose!!!"
Thanks all :)
Later,
Mike
LOL...Hay Goose,
I'm with Mike on this one. I seem to recall a knife & Pizza combo you had an issue with....:eek:remember:p. Just think what could happen with a pigsticker & marshmallow & a fire:p.
jb4570
You know Goose I was kinda hoping that Paul Bos would chim in
and give his 2 cents worth on this one.Oh well.I have seen it
done in westerns.
Hawkeye
hummm some how i expected you would have used the pig sticker to turn your spam over on the fire! :confused::D
or do ya not eat spam any longer?:eek:
Well guys here goes, 420-HC is tempered @ 375Deg F. Ats-34 is tempered @ 950 Deg. F same for 154-Cm and CPM-154, S-30-V @ 500 Deg. F. Hope this helps. Remember Knives are for Cutting, Screw drivers for turning screws, Chizils for Chizling, Branding Irons for branding. Paul.
