I started looking really close at the knife and found quite a few scuffs and abrasions around the handle. I decided to go ahead an use it to see what it would do. I trimmed some small limbs and debarked my wooden baton. I also did some other whittling and wood work. Finally, I chopped through some TV antennae cable. Other that some dirt on my chopping board causing some edge dulling, it went through all this, including the copper cable, with no sign of dulling or damage. It has a good heft, though the balance is still fairly neutral. During some of the chopping, I used a 2 or 3 finger grip. The blade has what I'd call a poor man's recurve. The blade at the plunge grinds is narrower by about 1/16" to 1/8" than at the belly. This gives a recurve like effect, while still giving the ease of sharpening of a straight blade. I had not really noticed before, but the back of the blade is perfectly straight. The more I think about it, the more I like this profile. I was a little worried about the point strength, so I did some digging in the wood. No trouble at all. After this little cutting session, it cleaned up with warm water and dish soap.
I find I don't really have a need for a 7" blade knife around the house. It's too large to be a dedicated cutter/slicer, and too small to be a brush knife like my reground (added a primary bevel) Cold Steel Barong Machete. I'll likely give it a good sharpening to remove the dull spots from today, and store it in the house instead of the garage. I also scraped off the little rust spots, and found no pitting underneath them. Another good cleaning should remove them. Hopefully, I'll pass it to my daughter. She's already taken a liking to it.
