- Feb 5, 2005
I just purchased a Buck Mayo Cutback (model 174) at a Wal-Mart in the northwest Denver metro for about $32 including sales tax.
The Cutback reminds me of the Kershaw Vapor, which is also a framelock with a satin-finish steel handle. The Vapor has a pretty solid reputation here in the forums, especially given it's price point (about $20). I would say the fit and finish on the Cutback is a little better than the Vapor overall, but the blade (which appears to be coated with Buck's TiNi coating, I *think*) is clearly better steel (440C vs. the Vapor's AUS6A). The Vapor's lackadaisical edge retention is the only major slam against it; knowing Buck's heat treatment methods, I'm confident the Cutback will hold its own.
The framelock is solid, engaging in the middle of the tang, but it disengages easily. Gentle-medium spine whacking against my thigh didn't produce lock failure.
The blade was just under shaving sharp out of the box - it could draw cut newsprint but not easily push-cut it. After about 10 passes on each side using the alumina ceraminc (fine) rods on my Sharpmaker, the edge was able to push-cut through newsprint with ease.
The ergonomics are very solid. I have a funny-shaped hand - wide palm but short, stubby fingers (I have to wear a men's XL glove so my palm fits, but the fingertips of the gloves extend a good 1/4" past my fingertips). Given my wide palm, I'm usually able to get a good positive grip on most medium-sized folders, and such is the case with the Cutback. Somebody with longer fingers might have issues, but in any case, the lock is recessed and I can't see white-knuckling the grip would accidentally disengage the lock.
My only real gripes are (1) the blade is rather stiff when opening; a good flick on the thumb stud can't quite get it open and (2) the pocket clip is very flush against the frame, so it's taken some effort to clip it into my right front pocket. I'm assuming both issues will take care of themselves as I use the knife.
For $32, I'm glad to add this knife to my EDC rotation.
PS - I thought of another gripe: now I want to get the Buck Mayo TnT.
As per the Buck Web site, the Cutback's specs are:
Weight: 3.3 oz. (92 g.)
Handle Material: Stainless steel with lightening holes
Carry System: Stainless steel clip
Blade Steel: 440C
Length Closed: 4 1/8" (10.4 cm.)
Blade Length: 3 1/4" (8.3 cm)
Country of Manufacture: China
Blade Steel: 440C
