Buck Sheath, whats is it for?
In my general looking for knives last year I ran across this sheath with a 112. they do not fit well. It will work with a 110 blade pivot down but not butt down. There are no numbers but the flap is embossed and the snap is marked "Buck". The length appears to be right for a 110 but I have never seen them with the edge spacer like the older fixed blades.
I thought about that but isn't the sharpening steel longer then the 110? I looked up the 137, your right it does look like it.
Thanks
Only photo #4 looks correct for Buck's model 137 Sharpening Steel. Yet, I'm guessing all photos are of the same sheath. Still, the others do not show the sheaths top with it's slant cut. That's the thing... So, many times members here want photos and when dealing with a stamp a good photo makes identification easy. But here I looked and looked at these photos and some look like a different sheath. So, photos
(these) can create confusion toward identifying and item. Plus, the photo we needed is one of the area at the top of the belt loop as that's where the model number was stamped on this item. DM
You are correct, if I get the light right I can make out the stamp, Thank you both for the help, now I'll have to find a steel to fill it and find another sheath for my 111.
