Buck/Strider folder - lock disengages under sideways torque
Cliff Stamp
BANNED
I have been using the folder for some time and was impressed in may ways with it. However one problem that I had was that if I exerted even a small amount of force sideways on the blade it could cause the liner to shift and then it would be very unstable and even a moderate amount of force down (or up) on the handle would cause the liner to pop off the tang. In regards to how much force was necessary, I could do it just by torquing my wrist, it was not necessary to lean into it at all. Is this the expected behavior of the lock?
Full details :
http://www.bladeforums.com/ubb/Forum3/HTML/002589.html
One other thing, what is the liner made out of and how hard is it?
-Cliff
Hey there Cliff,
Obviously not. Are you applying lateral force or radial force?
I can see that if you were to apply lateral force, you would be able to flex the blade away from the locking bar. Did you have the thing in a vice or handheld? Did you destroy the thing? Contact me if you did, I'll send you some replacement parts to play with.
Talk to you soon
Mick
Mick Strider:
<font face="Verdana, Arial" size="2">I can see that if you were to apply lateral force, you would be able to flex the blade away from the locking bar.</font>
Yes, this is exactly it. And of course as the liner moves off the tang, the blade becomes unstable under up/down forces. What surprised me was the amount of force required. It did not seem excessive to me .
<font face="Verdana, Arial" size="2">Did you have the thing in a vice or handheld?</font>
It popped off when I had the knife stuck in a piece of wood. I was flexing it side to side and up and down to work it loose and the lock disengaged. I then spent some time with it in a vice examing just how it behaved. I would estimate about 50-75 lbs of force was applied sideways sideways at max, and about 150-175 max lbs up/down.
Note that these relatively large up/down forces were not needed to disengage the lock if it was bent sideways. It would then disengage under moderate force, about 25-75 lbs depending on how far it was bent sideways. I just tried a couple of hard straight up/down thrusts to see how stable the lock was without sideways forces - it was rock solid.
<font face="Verdana, Arial" size="2">Did you destroy the thing?</font>
I snapped a pieces off of the end of the liner. I contacted Buck and Joe Houser wants to have a look at it so I am sending it off to him. If you want you can have a look at it as well. I don't mind the wait and would appreciate your thoughts on it.
-Cliff
[This message has been edited by Cliff Stamp (edited 02-12-2001).]
Hey there Cliff,
I would like to see the knife. Ill go over to Buck and see it while they have it.
I think this is something we don't see in many blades. It is probably because of the relative blade strength of the Strider/Buck. Most knives would lose the tip over the liner. Ill have to play around with it.
Thanks Cliff
Mick
