Buck Strider folder SBT liner locking to the extreme right
I just got a SBT, the liner is locking all the way to the right (when looking down at the liner), is there some kind of adjustment that can be done?
thanks
david.
i think that all of the liners by buck go all the way to the right, both of my linerlocks do that came from buck.
The tolerances are very close, but its still posible to get some varience on the liner position. Some people like the liner going further over. Some dont.As long as it holds.
Have you loosened the pivot a lot? Try tightening the pivot.
If that doesn't fix it, then the lock face on the liner is no good.
It shouldn't affect the lock up of the knife, however, it will reduce the overall life span as the steel wears down with use. The lock shouldn't engage beyond 3/4 over.
If it gives you trouble send it in and we will replace it.
Josh
Josh:
thanks for the info. how should I send it in? should I address it to a particular department? Please let me know the person/dept/or address to send it to.
many thanks.
david.
