- Oct 14, 2014
In an earlier post I made about older Bucks holding an edge better than newer Bucks, I noted that there was lots of opinions. I thought I would run a real world test of modern 420HC steel. I used a 2004 442 Buck for the test. I sharpened the primary edge to about 30 degrees and a micro bevel at about 22 degrees. The edge was beyond the hair shaving stage--it would go through phone book paper like butter.
I carve wooden flowers and their bases which I generally give away to church ladies. This is fairly hard wood and I normally carve them with Mora laminated and also Mora high carbon blades which RW about 60. I tried the Buck (it did not have the typical thin wood carving edge) and was astounded that the Buck did the job and did it just as good as the Mora knives AND it held its edge. It is still razor sharp. So I believe the new Bucks do very well in the edge holding department.
I can remember being at the SHOT show (I think it called something else now) when Buck showed the equipment testing the EDGE 2000 blades. I was a believer then and still am.
I see several comments about different steels and how much better they are than the standard Buck 420HC with BOS. I really don't know how true this is. I have seen rope cutting and other types of tests for edge holding and they always surprise the tester that the ordinary Buck low end knife keeps right up with some of the very top and expensive knives. AND they also sharpen up many times faster than the new expensive steels. So you can spend $150-$500 for a big name super steel knife or spend under $50 and get a knife that will keep up with the big boys and sharpen a lot faster. When I say "keep up" I mean in real life tests, the Buck equals or comes within 10 per cent of the higher end knives. This is not just my testing but other people as well.
Someone earlier mentioned the David Boye knives and his Boye Dendritic Steel. I worked for David at one time and I can tell you that they will hold an edge, but it is a very rough edge. If you want to cut rope and tomatoes, it is great. But for everyday use, I prefer Buck knives.
Anyway, I wanted you to know that in several different tests, the modern Buck steel is tested and true.
Thanks for listening to my story, Bryan
