Ok, I will show my ignorance here. Is that knife valuable because the Buck stamp is inverted? I am seeing only two pins in the scale and no other markings with the Buck stamp, dots, etc, so I am guessing this knife is maybe 30 years old? Would this vintage knife command significant monetary value?
Just learning.
thanks!
the inverted stamp dates from early 60's
some have a horsonal etch or stamp on the front or back
these years had some replace ment issues and were returned later
and buck jest replaced the thus they are hard to find in good condition
that is what makes them pricy
lots in rough used condition and they can make parts knives
some in not to rough are cleaned and used a year / verson display knives
the single line ( one line) lasted tell 68 when canada required
usa on the knife to comply with import laws there
the inveted contuned to when the 110 was added and it is very rare
then the tang samp was set to read with point up.
then there are the dot years tell 86...
the inverted stamp will show up every once in a while as some one
for grins puts a die in the machine back wards rare as it is not suposed to happen
but it does some times -most likely when they change the die and one or two get by
buck wast nothing uses every thing if it is good enught
here is one from a while back;
