- Feb 21, 2015
I know there's been plenty of steel threads, but I haven't found much info exclusively regarding Buck's 154CM and how it stands up to corrosion, etc...
Reason I'm starting a thread is because I've heard conflicting things about this steel in regards to rust. I know all SS can rust, but often read 154CM rusts easily, or has "excellent" corrosion resistance.
I was under the assumption 420HC was more corrosion resistant to 154CM, but was recently informed--by Buck--that 154CM is more corrosion resistant than 420HC. Is this experience shared with others here? Not sure if I was misinformed, or perhaps this is exclusive to Buck's 154CM?
Talking about 154CM and not CPM154 by the way. Does Buck ever use the CPM154?
Anyway, thanks for any info regarding this rather broad topic. I'm looking into getting the Buck CSAR-T Responder. Don't want a knife that needs to be babied, but it will certainly be cleaned and dried after use. That said, it might be out in the damp wilderness for hours and perhaps days at a time where things like oil aren't available.
New to this forum, hope this is in the correct place!
Thanks!
Thanks!
