Well, I won't buff with a wheel. I have sandpaper to 600 grit and then i picked up some 1500 grit SC sandpaper, and some whiterouge. I will drill it with a cobalt bit and use cutting fluid, Rapid Tap. For shaping, I have a jewlers saw I will use. I will use files to round the corners and a Dremel to smooth everything up, then hand sand to 600 and then 1500, then use the WR on leather and buff by hand that way. Would this be good? I won't pein the pins much, either. And I bought another pack of respirators rated form drywall.
As for UAI.org, i was going to use stag, but the guy at Texas knifemakers supply said I would probably run into the core because the knife has finger grooves and the tang curves down a bit, so I decided to go with the buffalo horn because i don't have to worry about the whole core and enamel. Plus, I had a bunch of stuff from Jantz on order, so I just added it to the order. Thanks for the help, guys!
[This message has been edited by Taz (edited 07-26-2000).]
