Buffing out 110 brass bolsters
morestag
What exactly would it take to buff or grind out some pretty good dents on the brass bolsters of a Buck 110?
Without power equipment, you can:
File the dents out with a single cut file, and sand with wet/dry autobody paper in grits 320, 400, 600, 1000,
2000 grits. Flat sand with the paper backed with a file or a piece of wood lath. Final polish with Simichrome on a soft cloth.
Bill
How about with just a dremel? No bench grinder or buffing wheel here at the moment.
No, don't use the Dremel at all. It will not work for that. There is not enough surface areas on the wheels to get a consistently smooth finish.
Use the method above, and the results will be fantastic.
Bill
Depending on how deep the dents are, you may have to remove a fair bit of material to get them all out.
I gave up on this on my knives because it would have left the bolsters much lower that the scales.
I just went for smoothing in the end and got great results with a bit of wood backing and some 600 and then 1200 grit wet/dry. A buff with a soft cloth, also on the wood backing and some polishing compound smoothed out the bottom and edges of the dents, and while not perfect, I didn't lose much brass or nickel-silver.
Greg
