You will need a stencil, an electrolyte (some people just use salt water), and a felt pad or other sort of pad to run the charge through which is soaked with the electrolyte.
No acids are needed, though commercial electrolytes can be caustic because of the various salts in them.
There's not much to it really. A DC etch will do a deep etch, removing metal (depositing it in the electrolyte soaked pad) while an AC etch will deposit oxide. Many people will do a DC etch first and then swap to AC for another period to get a nice deep etch with a black look. Personally I like the more 'frosted' look of a deep etch without any blackening.
Some etchers (as mine have) have an option for an intermittent / stuttered current in order to increase the life of a stencil and prevent overheating.
OK what is a Variac?replace the transformer with a variac.
It is a variable transformer...OK what is a Variac?
Where does one get one ??
Will it fit in the tutorial box ???
Google can be your friend on matters like these...
No, it will not fit in THAT box, but if a solution cannot be worked out for that minor problem, we probably should not be building this project....
