I'm about to build a small propane forge. I'm either going to do it out of a 40gal propane tank or a square box with fire bricks. Still have not decided which yet. Building it to heat treat a whole bunch of 1084 I just bought. I've read that 1084 is easily heat treatable for a rookie like myself. Eventually I will start pounding on stuff though
1. What do the real knifemakers here use, round forge or square forge?
2. I have decided to go with forced air burners over venturi burners. Should I do a normal flared end or a brick ribbon? I read that the brick ribbon burners use less fuel by running at lower psi and are able to get hotter and are just plain better.
I got good plans already found for both styles of forges. I'm just looking for opinions from you fellas on what you think is better. Thank you.
