- Feb 16, 2019
Edit: I've edited the name of the thread, as I will probably have some more questions and so I don't have to make new threads for every little question.
I am planing the build of a heat treat oven and have a safety related question related to the wiring set up.
Most of the detailed instructions and their wiring diagrams which you can find are for the US and it's hard to find a lot of info on single phase 230V set ups.
I want to include a main power switch and also a door switch and was basically thinking to wire it like this:
(fuses are missing here)
This way, whenever I cut the main power switch or open the door, there is no power on the heating element and safety is ensured.
However, all wiring diagrams I was able to find on the net, wire it the other way around: The phase (hot wire) is directly connected to the heating element and neutral goes through the SSR.
For example:
(source: https://www.indieknives.com/blog/knife-material-matters-heat-treat-oven-control-box/ )
In this case, when the switch is on, the coils have power on them, so I cannot safely open the door without completely turning off the PID.
Basically, they are all like this. This post gives an explanation (he had first done it the "safe" way): https://www.bladeforums.com/threads/diy-heat-treat-oven-question.622841/#post-6523780
He claims that this protects the SSR as it would burn faster than the fuse.
Can anyone chime in if it's okay to run the hot phase through the SSR and if my first diagram is okay?
Thanks!
For example:
Thanks!
