Graymaker, You can go ahead and add the tutorial to your site if you like. I've been meaning to get in touch with you about it. I've also submitted it to the CDK tutorials, but it's not showed up there yet.
Junkcarsrock, You should be able to etch as deep with this unit as you would with any electro etching unit. On many factory knives, the etching is only an the surface, but I usually etch deep enough that I can feel the logo by running my finger nail across it. This way it should not rub off over time.
Pendentive, You can order your own stencils already made up, or you can make your own by building a light box.
See Bob Warner's Website. The process is to design your logo on your computer and print it off on overhead transparency. Then cut a piece of photo sensitive stencil material and expose it, along with your logo, in the light box. Take the stencil material out, put it in the developer, and you have your own stencil. I get the stencil material, developer, and etching electrolyte solution from IMG.
You can find more information on this process on Bob Warner's webpage and by searching the Tool Time forum on the CDK forums.
I may be putting a detailed tutorial together on building and using the light box. If I can answer any more questions, just ask.
-chris
__________________
Chris Crawford Knives
