- Jun 21, 2021
Hey everyone, this is my first post. I’m towards the end of building my first forge. It is of my own design and was constructed out of one 3/16” steel sheet. I acquired about 8 Clipper bricks from a local soda kiln. These are extremely hard - difficult to even cut with a diamond wheel. Additionally, I picked up about 10, what the seller believed to be K23 bricks. They’re very soft and can be shaped quite easily. I opted to make a box and inlay the Clipper bricks inside for the floor of the forge. Then I made the top a two burner and lined it with 2” of Kaowool. I welded tabs on the sides of both pieces so that I can easily remove the top for repairs in the future. I tried to design something with a lot of forethought so that it would last me as long as possible.
After doing more research, I’ve read that often times the hard bricks are better heat absorbers than they are heat reflectors. So my plan is to coat the entirety of the floor and the inside of the top portion with ITC-100 and try and prevent that heat absorption. I didn’t want to swap out the bottom with the K23 bricks because they’re so soft that I’m concerned that they would just wear away with use and sticking and dragging metal in and out of the forge. Luckily, I can still do that later on if I find that the Clipper bricks aren’t doing the job - hence the removable lid.
https://flic.kr/p/2m6RVzw
Currently, I’m at the Satanite stage of the process. I put some between the bricks for the floor and now I’m working on the lid - as seen below. I’ve done my first layer really thin after reading some other posts. And then yesterday I did the next thicker layer. I took the torch to it this morning after nearly 24 hours and the refractory begins to turn brown - almost as if it is burning. Is this normal? It makes me hesitant to hook up the burners and do a low quick burn. Should I wait until I’ve built up all of the layers and then do the firing of the burners or do it for each layer even if it begins to turn brown? I see a slight bit of cracking in the corners, which I need to repair. But I’m not sure if that should occur before or after the firing in case that crack grows.
https://flic.kr/p/2m6RVGR
https://flic.kr/p/2m6UJvh
Thoughts on the design? I have the floor hanging out on each side the width of one brick so that I can turn a brick on end to close off the forge when needed. But I can also remove it for working on longer projects. I also added all-thread handles on both sides for tool rests and for anything I want to add on in the future.
Thank you in advance for your input, answers, and advice. Cheers.
Seth
Seth
