- Dec 30, 2007
I have been carrying my orange Bullnose every day for about a month and thought I would be a good time to post a brief review. I purchased it some time ago and carried it for a bit but set it aside as I really didnt warm up to it. I think my preference against half stops played a major role in this. Seeing a lot of positive comments about this knife on this forum made me decide to give it another try and make it my primary traditional pocket carry knife for a while. I usually also carry a one hand opening knife (Benchmade) clipped to my pocket but decided to carry the Bullnose solo most of the time to force me to use it more. My sodbuster reference is a yellow Case Sodbuster Jr. with CV steel which I have frequently carried for many years.
I expected the fit and finish to be a little better for a knife in this price range. There is no noticeable blade play when opened. There are no gaps in the liner. The back spring is slightly recessed when closed and stands slightly proud when opened. The blade is slightly off center when closed. The Delrin scales could have been finished a little better. The lanyard hole was not chamfered and had sharp edges which would probably wear into a lanyard if used. This was a quick fix with a countersink in the drill press. It has a pretty stiff back spring, I find it too stiff to reasonable open the knife with a pinch grip. As a comparison I have none of these issues with my Case Sodbuster Jr. which cost me less than half as much as the Bullnose. The blade snaps into the open, closed and half stop positions with authority
I really like the size of this knife and the way it feels in hand. I like the orange Delrin scales. I like the blade shape and the O1 tool steel. I dont care for blade etchings. The blade was sharp out of the tube. I find the blade easy to sharpen and it holds an edge well. It performed well cutting up some large double wall cardboard boxes. I dont see any major advantage of the O1 over Cases CV steel though. The blade isnt showing a patina yet.
The back spring is so stiff that I find the knife awkward to open and close at times. I cant reasonably open it with gloves on. I may try to modify it Bullnose with an easy open cutout down the road. I will go back to carrying the Sodbuster Jr. soon and see if I miss the Bullnose. I really expected to like this knife more than I do. I was expecting a higher quality version of a Sodbuster. In my opinion this knife would greatly benefit from not having a half stop and a more reasonable back spring tension.
Greg
Greg
