I seem to have developed a burr on my P-Millie in S30V. I tryed quickly to reduce it last night, without much luck. I am thinking of taping a dmt blue stone to one of my spyderco rods to make a go at reducing it, any other recommendations?
Find Jeff Clark's post on burr removal. (If I find it, I'll add it here). Basically, you make a few alternating strokes at a higher angle to deburr. If you're using the Sharpmaker, he rotates the knife out so that it matches the angle of the opposite rod, then makes a light stroke. Once the burr is removed, he then makes a few final strokes at the original angle to clean up the edge. Going to a more coarse stone, isn't the answer.
You'll need to get to the third page of this thread before you find my standard deburring approach. This topic evolved to some deep trouble-shooting of problems with various edges. My first recommendation was the killer approach for a really bad burr. You have to interpret my first comments in that light. I sort of reduce my recommendation further down the thread. I assumed the original poster was fighting a bad mutha. http://www.bladeforums.com/forums/showthread.php?t=355227
I would not expect S30V to be much inclined to forming a burr. It is a hard alloy with a controlled smallish carbide size. In general I would do most of my work on S30V using diamond hones. My final deburr would be just a few very light edge-forwards honing strokes at about a 5 or 10 degree elevated angle relative to what I used for most of my honing. You can do this by tilting your hone slightly from its normal attitude for example. Then I go back and do a little more honing at my normal angle to remove any residual shoulder left by my deburring process.
