- Oct 17, 2007
I'm piecing together parts for my first propane forge, which is going to have (at this time anyway) a single forced air burner. I'm using a 10 gallon portable air tank for the housing, and plan to line it with at least a couple inches of kao wool, followed by a coating of refractory cement.
Right now I have the front cut off, with plans to make it into a hinged door with a smaller "regular access" opening cut in for normal use. I'll probably also make some kind of pass through in the back eventually, for longer pieces, but right now that's not a huge priority, and I may hold off for now.
My next consideration/question/problem, is where or how I should insert the forced air burner...
Should it go towards the back? Dead center? Towards the front but angled toward the back? Should I do straight down from the top? Come in from the side? Angle it for a swirling effect?
This is the tank (or one very similar) that I'm using. Should I just position the burner where the fill fitting was positioned? Am I over thinking this?
I appreciate any insight/advice....
