Django606
- Jul 22, 2005
I'm having trouble identifying and removing burrs. If it matters at all, the steel is 154CM. I find it very hard to tell which side the burr is on, and if I have ground it off completely. I'm using the Sharpmaker. To check for the burr, I was following the eGullet forums sharpening post, which said to hold the blade horizontally and brush your fingertips down the edge at a 45* angle. I find it very hard to check if the burr is actually there or not using this method.
Also, how would you reccomend I remove the burr? I have been tilting the knife slightly towards the center of the Sharpmaker to increase the angle when I try to remove the burr. I press very lightly, which doesn't seem to grind the burr off, and then I try a little harder, which just pushes the burr over to the other side. This, and the fact that I have trouble detecting the burr in the first place, make it very frustrating when I try to put the finishing touch on my knife.
My main questions are: What is the best/easiest way to check for a burr, and what is the best/easiest way to remove a burr?
Thanks in advance for any help.
Edited to add: I am concerned about this because I thought I had ground the burr off completely, and the knife push cuts news print very easily, but when I went to shave my arm, one side was much better than the other (one was hair popping, one was barely shaving.) I know some people have said that this occurs because of a burr, but I was almost positive I had ground the burr off. Also note that I have not sharpened the knife all that much, I just sharpened it enough on the flats of the fine stones on the Sharpmaker to achieve a burr.
