- Sep 19, 2001
Why is this done? If you form a burr, that means one bevel has met the other at a thin enough edge radius to form the burr. I can only see burr raising twice if the angles on each side are uneven. The edge radius itself is already thin enough for a burr, so making it all over again at the same angle isn't telling you that the edge itself is any sharper.
It can take a lot of strokes to form the burr the first time, when the blade is dull or you are changing edge angles. Then, it just takes a few to remove it. After that, it only takes a few to reform it, because you don't have to reduce the radius anymore for burr formation.
