- Sep 7, 2016
I had some interesting results using Busse Elmax to make some feather sticks on twigs. Unfortunately, I had a few cocktails in me and did not take proper pictures so you will just have to take my word for it.
I was doing some testing on degrees per side (DPS) for a Max Duty and a Max Warden. I sharpened both blades on a KME sharpener to .1 micron on the leather strop. The Max Duty got a 13.5 DPS and the Max Warden got a 15 DPS.
I was making some feather sticks with both of them and they cut through like butter and did just fine, I made a few feather sticks with each then went to touch them up on a leather strop. When I touched them up I realized that the 15 DPS Max warden had encountered some rolling and created a burr that was snagging the strop. Like I said I had some drinks in me so I didn't think twice about it and put it on a stone and fixed the rolling and proceeded back to the strop, (forgot to take pics).
The Max Duty which was at 13.5 DPS had no issues and was still razor sharp and begging for more. I didn't do anything different between the two and I were using the same twigs. Any idea what may have caused this? Could it be user error? At times I would use my thumb on the spine with a slight rolling motion to see how to find I could cut strips of wood but I was doing this on both blades. This is no way a knock to the steel because both held up just fine. The Max Warden at a higher DPS just happened to have some slight rolling which fixed right up.
So the main questions are why would this happen on the higher DPS blade and no the lower? Just circumstantial? Once an area is rolled and repaired is there any degradation to that area for the remainder of that edge/shoulder until it is re-profiled or resharpened?
What is your preferred edge for bushcrafting? I still need to do more testing but I definitely did not expect the elmax to roll at 15DPS when people are chopping at 15 DPS with no issues, but then again the 13.5 DPS did not roll...
