Bush Sword WIP 36in CPM 3V
Huntsman Knife Co. LLC.
Moderator
Hope I'm not breaking any rules by posting here but I figured you guys might like to follow this build along.
So here's my latest project. This is an order for a customer. I've been wanting to make a blade like this for years but never had the time to get around to. The original plan for this blade was S7 and micarta, but we decided to go all out and step it up to 3V and Terotuf. Getting to make a sword like this is a dream come true for me and I can't wait to see how it turns out.
I apologize in advance for the crappy pictures. My phone doesn't have a very good camera and I don't feel comfortable taking my Mark III 5D into the shop. There will be some good pictures when its finished.
It all started with a CAD sketch. Made a few modifications for the customer and then got it cut at the water jet.
She has arrived!
I came home last friday to a massive piece of .180 CPM 3V waiting for me on my porch.
I wasted no time and went straight for the dykem. Also got in a sweet sheet of orange Terotuf. I'f you've never used terotuf, its hands down the best material out there for hard use knives. Its crazy grippy and tougher than G10. Ill be making it a permanent handle option on all my blades.
Being the mad man that I am, I decided to hard grind the blade. CPM 3V at 60RC is a bear to grind even in a 5in knife...a 25 inch bevel is a whole new level of pain. So I began chipping away. This thing chewed up and spit out 36 grit Cermaic cubitron belts like they were nothing.
I like to scribe in center lines and then set the initial bevel on a 10in wheel with an old belt. Here she is with the bevel set and ready to hit the flat platen.
After about two hours of grinding the bevels begin to really take shape. The recurve presents a few challenges but after a few passes I got the motion dow. I had to run my grinder at full speed and use high pressure to remove any steel even with a fresh belt. Definitely won't be hard grinding one of these again. I take the grind to where the balance feels good and then stop.
Also, I really need to clean my shop. I promise its not that bad all the time. Ok, its that bad most of the time. But when you get in the zone stuff gets messed up.
Here she is with the bevels roughed in and finished to about 120 grit or so. Now comes the fun part, finishing the flats.
Finishing the flats was an absolute nightmare. First I tried surface grinding them with my awesome Travis Wuertz surface grinding attachment, but this blade is so long and flexible that I couldn't get an even finish. I then had to go to the platen and grind the flats by hand. This took about 4 hours and was a very frustrating process. In the future, I will probably just use non precision ground steel and leave the flats unfinished like I see alot of other guys doing.
This piece is no beauty queen, but on the budget its being built, it was never meant to be.
Here's a couple recent pics. When I do big blades I like to flat grind it and then switch over to the rotary platen to give it a convex. A slightly convex grind reduces sticking on deep chops and also is slightly stronger than a true flat grind.
This is finished out at 280 grit on the rotary platen and then hit with a cork belt. The bevels turned out pretty well. They are even and while there's a few small imperfections, for a 25in recurved bevel, I think they look pretty good. As for the flats, they look OK but have some scratches and imperfections but at the end of the day I'm very happy with how the blade has turned out. I might hit the flats again with a 320 grit belt but at this point I think they are about as good as they can get. Having a disc sander would have been a big help during this process but I opted to purchased a surface grinder instead.
I took the edge down to .008 before sharpening. This is the thinnest I've ever taken a big blade and I'm excited to see how it does. I take all my 3V knives this thin or even thinner before sharpening and they hold up to batoning and everything just fine so this edge should still be very durable even with it being very thin.
This angle allows you to see more of the flaws on the flats. Some 180 grit scratches are there and theres a few areas with a bit of unevenness but theres not alot you can do.
My mind boggles at the time it must have taken to grind that heat treated... I grind mine first and then send out for heat treat. I guess the advantage you get is that you don't have to worry about warp, but man, I think I'd quit if I had to grind hardened 3V in sword length...
a 3hp motor running at full speed helps but yeah, I won't be doing that again. I prefer to hard grind because I like the way the steel moves across the platen but Ill limit that to small knives from now on.
On of the main reasons I hard ground this was to to take out any chance of warp. I know its a plate quench, but last time I ground a really big blade soft, I ended up bending it from just the pressure of grinding on the platen.
WOW! That is looking AWESOME!!! :eek: ---- :thumbup:
I can't wait to see her when you're done!!!
nicely done. at this point i grind the flats heel to tip on the contact wheel, vertically. if you have a steady hand it actually works pretty well.
still haven't messed with 3V yet.
Nice looking piece. I think 0.180 is a good thickness for a piece like that; thick but not overly heavy.
Well this one has ended in tragedy.
I did some rough shaping and temporarily attached the handles to do some testing. Day 1, this thing performed even better than I hoped it would. It destroyed everything in its path with ease. Where it really excelled was brush and small diameter trees. It completely sailed through both like they weren't even there. For some harder use testing, I chopped an old locust fence post and while it didn't do much to the fence post, the edge was undamaged and would still shave afterwards. After 1 day I was really happy with its performance but decided to take it out again for a little more chopping.
Here's where it all went downhill. I was taking out a few small 6-8in diameter trees and was really getting comfortable with my strokes and swinging about as hard as I could. I chopped into one of the trees at an angle and ended up hitting a huge knot that was hidden within the tree. When I pulled the blade out and saw the damage I was crushed. The pressure from the softer surrounding wood wrapped the edge around the knot and caused a huge roll. Needless to say I simply ground this blade too thin for the power you can generate with a two handed swing. The sword is effectively ruined and I'll be starting on another one shortly. Gotta just learn from the mistakes and keep moving forward.
But all in all, I couldn't be happier with the performance of this blade. Its a complete monster and with the exception of the rolled edge was impressively tough. It flexes really well and the edge will still shave even after all its been through. With a thicker grind this sword is going to be just killer. In the mean time, I'm going to test this blade to destruction and see what its really capable of when pushed to the limit.
A little flexing. It can flex way more than this but I had a hard time getting a picture of it.
She bites DEEP.
Cue the tears. Here's the nasty roll that send this beast into retirement.
Now that is some sad news man. I hope that you will share the ongoing testing and next build. I really liked the look of this sword.
live and learn my friend, nothing like hands on experience to figure out when you are pushing a sword too far. But sorry to see that after the hard work
I....I..I want one.......and I have access to a water jet......this is not a good combination. Maybe a thicker blade, say .200 or .225?
I too have always liked that style blade, just have never had the chance to make one.
