Bushcraft 2009 ...... a question
Here's a drawing showing the first production run on top, then the template I am now using for all bushcrafts "in the works" and then on bottom the new design - which I have further modified.
The cool thing about the third design is that those the liked the first two won't be affected by the new third one. For example, if the first-run knife fit your hand well....the new one will still fit your hand. But now it will also fit those with wider palms and longer fingers. And if you liked the guard...you'll like having a little more guard.
So, I think overall...I really like where this is headed.
The striker tip is part looks and part function (aids in penetrating materials). It's not a swedge...totally different. If you look at the tip from the top (spine) not much material has been removed. Just enough to help you get the knife in deeper into whatever it is you're using it for...including opening letters, cutting cardboard, carving wood, digging, drilling holes, cutting leather/skins, skinning, stabbing, and so on.
I call it a striker tip because I respect Busse and don't want to piggyback on their great ideas/designs.
I put it on a bushcraft because I was having trouble doing fine cutting in soft materials...the thickness was destroying the materials...and sticking the knife straight into a material required more force than I wanted. After getting the striker tip, all the above activities were much, much easier.
And as far as I can tell, it does not weaken the tip.
I grind it at the same angle as the scandi grind...so, it's pretty stout.
....I think it may be a "done deal" now....I'll start a poll next week to see what everybody thinks overall...
Dan
Dan......... the question ?
When the time comes for you to make the bottom knife.....
..........will you make it of .. CPM 3V ....like most of the other fine Bushcraft models ??
[Don't say "no"... I have waited too long for this knife.] ;)
MERRY CHRISTMAS ............
teacher
#1 is the First Production Run - hopefully easy to identify visually
#2 is the current batch (with the exception being that the guard is now a little longer)
#3 is a design - not in production yet
:thumbup:
The reason I call them v3 is not that it is the 3rd in that pic...but that they are a result of the 3rd run I have made. I did one run of #1 above, one run of #2 above, and one run of #2 above again but with slight modifications.
To date, #3 does not exist...it is still in the concept phase.
Dan
Dan
Dan,
When the time comes that you make the much discussed bottom knife / #3 above........
Will you make it in CPM 3V also?
[I, for one.. hope you do...] :thumbup:
not sure yet....that's all I can say...
Dan
I am torn because I really like 3V and this knife has kinda made it's own niche with this grind and steel.
But I don't want to neglect the stainless possibilities....CPM154 would make a great scandi-grind steel.
Maybe I should do both?!?
If you want a toothy-edged steel get CPM 3V
If you want an easily-polished stainless get CPM 154
That's an idea....something to think about anyway.
Dan
Dan
I can understand that.
I really do hope CPM 3V is at least a choice for this knife... so. both would be good... :thumbup:
I have come to consider 3V a favorite of mine... a super steel ... in my book anyway. :thumbup:
You know Dan, I have been thinking about this - I think enough 01 has been done. Do a run of both - I think that would give your niche a shot and an option for those who want a little more ease in sharpening.
TF
Sorry if this has been asked before (I can't seem to find the info), but is this third production run still slated for this month? Really looking forward to picking up one of the venerable Koster Bushcrafters, and I want to make sure I keep my eyes open for the official order thread :)
Yes...probably in a couple weeks. Eyes peeled! :eek:
Dan
I have Bushcrafters in both CPM154 and 3V, either way would be great. Both of these knives work very well.
