Do you think a bushcraft knife should have a specific grind on it or is anything okay? I prefer a Scandi grind and will only buy a bushcraft knife with one. What do you think? And what is your Bushcraft or "Woods" knife?
The "Scandi" grind is the same as saber-grind with no secondary (micro) edge-bevel. This leaves a thick stock that increases the strength of the knife and assures a thicker apex-angle for edge-durability. However, weight is reduced and cutting performance is drastically improved by reducing the bevel angle into a full-flat or hollow grind, even with a secondary micro-bevel, and such an edge is also much quicker/easier to restore. You do lose some of the lateral strength/stiffness of the blade and the durability of a fatter edge, but this may end up being an advantageous trade-off. With better steels and optimal heat-treatment, you can slim-down you blade and narrow your edge for a lighter, faster, sharper, lower maintenance cutting tool. :thumbup:
That said, my woodcraft knife is a Cattaraugus 225Q -
THICK stock for heavy prying, a fuller to reduce weight, 6" flat saber-grind to give this pry-bar an edge with reach, spine-swedge for improved penetration, comfortable "grooved" leather handle, hidden-tang, thick hammer-pommel. It's my splitting-wedge, shovel, hammer, prybar, cutting implement - and to me,
that multipurpose design is what makes it exceptional as a woodcraft tool. You can keep your bushes, we have trees here.
