Bushcraft question
Just curious about what the gray finish on the flats of the 3V bushcraft is and if it is either the passivation(sp?) I have read about or some other rust preventative, would I be begging for rust if I polished the flats? Also, would polishing remove the etched K? BTW, I love the knife, thanks Dan.
I nearly missed your question - sorry about that!
The flats of the 2009 Bushcraft knife are satin finished. Meaning, the blades were surface-ground before heat-treat, bead-blasted after heat-treat and then finished out by hand with a scotchbrite pad.
If you polish the blade you'll mostly likely remove the darkness of the logo, but it will still be there (deeply etched).
The previous versions of bushcraft knives in 3V had the 'as-forged' finish that came on them straight from the steel mill. Not as good-looking, but tougher and easier to maintain (imho).
Dan
I would have a hard time choosing between the as-forged vs. bead-blasted finish. They both have a "I'm here to do business, and business is good" look. I would like to see a polished one to see if fits in!
I do plan on doing a high-finish version next year in CPM154. Eyes peeled...!!
As I have been given to understand, a bead blasted surface has bits of ceramic material embedded into the steel. It serves as a reasonably good rust resistant surface.
I would be concerned that polishing the surface might remove this material....
Kindly correct me if this is wrong.
I wish it were true, Kwai. :p
I don't use ceramic glass beads - those do give a nice finish, but are finicky, slow-going and expensive.
I use 120grit silcon carbide beads.
The best way to think of it would be this:
Imagine you and, say, 10,000 of your friends each bought a ballpeen hammer and covered the ball end with 120 grit paper. And then I turned you all loose on a giant sheet of steel as big as a warehouse floor...to beat the crap out of it.
If I only leave you for a few minutes, I would just end up with a bunch of random dents in the steel floor. But if I left you all there for a few days...eventually I would end up with a million little dents in the floor and the surface would be very uniform. Bumpy, but uniform.
That's what bead-blasting does. It hits the steel and "micro-dents" it, turning it in to a "bumpy" surface that no longer reflects light but scatters it.
Bead-blasting actually makes a knife more likely to rust....because it leaves it with a 120 grit finish, and many more places for moisture to stick to (a la surface tension).
Polishing is the best rust-prevention...and works better with steels that have more chromium in them.
Dan
