If I may "borrow" the thread - Maw, what are the knives just below the Bushcrafters in your left column of knives? Are those Bushfingers? What are folks' thoughts on Bushfinger vs Arete for a good mid-size bushcraft/utility knife?
Hi BlackKnight86,
The knives in the left column from top to bottom are:
Bushcrafter (convex grind)
Terrassaur (convex grind)
Terrassaur (scandi grind)
Ladyfinger (convex grind)
Hunter (convex grind)
The knives in the right column from top to bottom are:
3-Finger Joe (convex grind)
Bushboot (convex grind)
Hiking Buddy (convex grind)
KE Bushie (scandi grind)
Arete (scandi grind)
Arete (convex grind)
Kephart (convex grind)
Bushfinger (convex grind)
The Bushcrafter, Arete, and Bushfinger are all roughly the same size in length. The Arete's blade has the least width as measured from spine to cutting edge while both the Bushcrafter and Bushfinger blade's are wider. The Bushfinger's blade is also pointier than the Bushcrafter. One may argue that the Bushcrafter has the strongest tip due to its design if that is a concern for you.
They are all so close for me that it comes down to personal taste. I like blades with the width around an inch give or take a tenth of an inch. Hence, I favor the Arete and Kephart. They will all perform for sure, and probably sing a louder tune per se when in the hands of someone who has called it their own and enjoys its companionship.
I hope this has been of some help to you. I do wish you are able to find the right knife that will sing a loud tune in your hands.
Sincerely,
Mark
