I have access to a lathe so I should be able to drill and ream a very square hole. I may go over to the machine shop and see what they could do for meBased on the one I have you will just need that hole suuuuuuuuuuuper square and accurate to the face, then some kind of plunger to give some pressure from the back. Its a basic tool. The costly part is all the little fittings that allow you to use many different size bushings. If you use one size, it seems to me it could be made fairly cheaply but as usual, its probably more complicated than that.
thanks stanley, sounds pretty simple. ever had a problem using non hardened steel?I made my own from 1-1/2 stainless rod, face off on the lathe drill and ream, parrt off and surface grind. Plunger can be made from round brass stock.
No, as long as you lap on a surface plate and keep it flat to the plate.thanks stanley, sounds pretty simple. ever had a problem using non hardened steel?
Thanks for the help, gunna make one up soonNo, as long as you lap on a surface plate and keep it flat to the plate.
