Busse Basic 9 = SR Battle Rat??
There's no talon hole :p The handle molds are also slightly different.
Also, one is no longer in production.
Steel? Aren't the Basics made of mod INFI, whereas the Battle Rat is SR101/52100.
David
the battle rat has a thicker squareish handle that has a consistent texture over the entire thing. it is a larger handle in general.
the basic 9 has smooth resiprene c and a tredded area near the front on the flats of the handle, and a textured area near the back of the middle of the flats of the handles.
the basic 9 has a talon hole and the battle rat doesnt.
the battle rat is, in general, a thicker bulkier knife then the basic 9. the basic 9 is fully flat ground ,and the battle rat is a high saber, both at 1/4" thick.
i carried the basic 9 for a long time, and i regretted having to sell it (went to a varient handled and serrated terror monkey battle mistress, cant have both unless i intend to carry both :( ), and still regret not having it. its truly a bueatiful work of functionality. some say the handle was a bit to small (not thick enough) , but i loved every last bit of it.
battle rat never really sat well with me... seemed to bulky for what it was, like it could have been thinner and still maintained its strength (like the special run of satin battle rats). and i love the handle on the basic 9 waaay to much to take the br over it.
This summer I owned both at the same time, and preferred the Basic 9 due to handle and blade shape. SethMurdoc has already covered most of the differences; I'll just add a couple points. First, the handle swell on the Basic is slightly less drastic than on the Rat, and I found the softer Res C more comfortable on the Basic as well. But by far my favorite thing about the Basic 9 was the blade. Though the Rat and the B9 have nearly the same length of blade measured from the handle, the small choil on the Basic means you have quite a bit more edge. This, combined with the narrower blade SethMurdoc mentioned, makes for a wicked-looking knife. Looks don't have any effect on performance, but I found myself smiling every time I unsheathed the Basic 9. :)
I was nerdy enough to take some measurements when I had both. :rolleyes: :D
Basic 9 Battle Rat
OAL 15 14 1/2
Blade length 10 9 7/16
Handle length 5 1/16 5 1/16
Choil width 9/16 1 1/16
Edged blade 8 15/16 7 7/16
Blade width 1 5/8 1 13/16
Grind width 1 5/8 1 1/4
EDIT- the spaces disappear when I submit the post. :mad: Not sure how to unjumble it.
I did this with a long ruler, so error is about +- 1/16. Thats why the Basic's blade + handle doesn't exactly equal its OAL.
From the numbers you can see the Basic 9 has a narrower, longer blade with more edge. The Battle Rat has a choil you can put your finger in to choke up on the blade.
As mentioned, the steels are different. The tempering of the blades is also different: the Basic 9 is through-tempered (i.e. the same hardness throughout), while the Battle Rat is differentially tempered (the edge of the blade is at full hardness, while the spine is softer. This makes the blade less likely to break under lateral load (than a through-hardened knife of the same geometry, heat treat, and steel)). The Battle Rat also has the Busse penetrator tip, while the Basic does not.
The Battle Rat is still in production, while the Basic 9 was discontinued years ago. Though both have the same warranty, if you somehow manage to monkey up your Basic 9, the Busse shop won't be able to replace it with another Basic 9.
The Battle Rat is less expensive. The cheapest I've seen a Basic 9 sell for here was mine: $150.00. Most are sold for $180-200. The Battle Rat is around $150.00 plus shipping from Swamp Rat.
The early production Basic 9's had a smooth black epoxy coating (like mine) and black handles; later production had the tougher black crinkle coat with black handles. The Battle Rat is available in black crinkle coat w/black handle or in desert tan crinkle coat w/tan handle. The desert crinkle coat is supposedly more durable than the black.
This is all I can think of (I'll exclude sheaths from the discussion because a wide array of custom sheaths are available for both, and I'm getting tired of typing ;) ).
Jeremy
I own both, or did. I gave my Battle Rat to a friend for his 50th birthday. The only thing I would add to the above is that the Basic 9 has an asymetrical edge grind, while the BR has a symetrical grind. I prefer symetrical grinds myself.
Steelhed, good call on the edge grind. Not sure how that slipped my mind. :confused: :D
Santi- which knife did you decide to buy?
Jeremy
YEAH, good thing I bought two each when they first came out. Now I only have one of each left.
