Busse, Cold Steel, Fallkniven revisited
RokJok
To a large degree this is simply an extension of earlier tests I've posted to the Reviews forum, since the results serve to reinforce expected results from various blade geometries. I spent a couple of hours Sunday testing and illustrating edge geometry for a friend with whom I attended a local gun show. After the show we took the blades into his basement to test their wood cutting and chopping characteristics. These are the subjective observations that came out of that session for us.
The knives we used were a Fallkniven A1 in VG10 stainless, Cold Steel SRK in Carbon V steel, Cold Steel large Twistmaster clip point in Carbon V steel, a Victorinox SAK with 3" large blade in stainless, and three Busse knives: a Busse Basic 5 & Basic 7 in M-INFI, and a Battle Mistress -E in INFI. Extraneous tools used were a cheapo pruning saw (Japanese pull-stroke coarse-toothed and deep-gulleted blade configuration), a short Stanley toolbox crosscut saw (standard western push-stroke fine-toothed config), a 16 oz claw hammer, and an Estwing camping hatchet that was about 12" total length. The hatchet was hollow ground from the hammering face down to the chopping edge, which was somewhat dull & blunted although not chipped.
The condition of the blade edges were:
- A1 = not shaving sharp but decent, what I'd call a "working edge"
- SRK = very sharp, fresh from a session on the Sharpmaker
- Twistmaster = NIB, which was very sharp
- SAK = very sharp, likewise unused since a Sharpmaker session
- Busse Basic 5 = compromised edge, somewhat dulled. Rolled along some sections of the blade.
- Basic 7 = not quite NIB, had seen some duty chopping apple branches since NIB, but still decently sharp
- BM-E = not shaving sharp, another "working edge" that had seen some use, but still remained reasonably sharp since its last sharpening
In earlier tests, the wood I worked with was green soft branches ranging from toothpick size to about four inches in diameter that I cut off of large bushes (~20 ft tall) along the fenceline. Chopping and whittling on that soft fresh wood allowed decent baselining for various blade thicknesses, geometries, and sizes. This Sunday we had some different stuff to work with and we were specifically testing for performance variance across differing blade geometries. We used a 1/2" thick x about 1-1/2" wide piece of dimension lumber that looked to be some kind of pine by the grain pattern for testing whittling/carving/cutting abilities of the blades. The wood was quite soft and of very low density. The other wood there to work with was approximately 2.5" thick sections of pine (maybe fir by the look of the bark) branch that had lain beside the furnace in his basement drying out for about three years. Consequently the chunks were very dry and hard; extremely well cured by the warmth.
We first tested the various blades' carving/whittling/cutting abilities on the very soft dimension lumber. We ran two rounds to produce both thin shavings and very coarse chunks. This approximated making fine delicate shavings for catching a spark in firestarting and rapid hogging off as much wood at a stroke as the blade would produce as if creating shelter poles in a hurry.
  • A1 = did fairly poorly compared to the other blades at producing thin shavings, but worked very well for digging in and removing a lot of wood in a hurry for the bigger chunks. The thick convex ground blade produced heavy chunky curls that were comprised of individual segmented chunks of wood (maybe 1/16" thick or less) that were stacked offset-wise on each other to create the overall curl shape. The blade immediately behind the edge was actually breaking off & pushing aside these little sections of wood after the edge had cut them.
  • SRK = worked quite well for slicing off both thin shavings and thicker chunks by merit of its very sharp edge, although its control was not equal to the SAK
  • Twistmaster = much like the SAK below, except that it's taller blade made it harder to alleviate pressures by changing the blade-to-wood angle if you found you'd entered the wood at too steep an angle. The flat-ground thin-stock blades really shone in this testing as being cutters extraordinaire!
  • SAK = worked quite well due to its thin stock & not tall blade that allowed good control for thin shavings and sharp edge that allowed the blade to keep digging deeper when used forcefully to hog off big chunks. I would worry about breaking the pivot pin on the knife if it were to be used in this manner on a regular basis.
  • Busse Basic 5 = didn't do very well for either thin or thick when compared to the thin-stock blades or the other Busses due to its compromised edge.
  • Basic 7 = worked fairly well for thinner shavings, although not to the benchmark of the SAK/Twistmaster, and did very well at removing a lot of wood in a hurry.
  • BM-E = did okay with the thin and did the best of the thicker blades (Busses, A1, & SRK) due to its longer edge being able to present vastly more cutting edge to the medium being cut on a draw stroke cut.
Next we laid the dried out pine branch that had been by his furnace on the workbench and took to chopping on it with the various blades. After working with considerably larger green wood (4" vs 2.5"), this dried wood shocked me with its resistance to blows. Whereas the soft green wood I was used to working with might take a dozen or so BM-E blows to sever the branch, this dried piece of pine took many many blows from each of the blades and we still only got a bit past half-way through it. As the cutting test above illustrated the influence of blade geometry on that aspect of working the soft wood, this work illustrated the influence of the condition of the wood on the efficiency & speed that can (or cannot) be achieved in chopping the wood.
  • A1 = did sort of okay, but it was slow going and didn't fling off terribly big chips which says it wasn't penetrating very deep per stroke. Since the wood was so resistant to deformation, it wasn't allowing the A1 in very far before the convex grind presented enough resistance to further penetration that the blade's progress was halted.
  • SRK = did sort of okay at first, but its short blade didn't have enough mass to drive its sharp edge very deep as we chopped deeper into the cross-section of the branch (i.e. were chopping wider & wider sections of wood).
  • Twistmaster = did poorly in spite of its very sharp edge. It is too light to be effective against such hard wood.
  • SAK = didn't even try this one
  • Busse Basic 5 = did poorly since its trashed edge kept it from digging in much at all. Plus like the SRK its short blade didn't provide enough mass to drive it into the stubborn wood with much authority.
  • Basic 7 = did reasonably well, being able to chip along as we progressed down into the heartwood. But it was creating smallish chips as it went. To use this blade alone to chop much wood this hard would take a lot of energy out of you.
  • BM-E = not surprisingly this was the best of the knives, cutting clean-sided strokes and creating larger chips compared to the other knives as deep as we chose to cut into the branch, which was slightly past the center of the branch. The surprise here is that the BM-E continued to cut when the hatchet would no longer cut & chip the hard wood.
After trying to cut through the notched section of the branch with the Stanley toolbox saw and making extremely slow headway, we used the pruning saw to cut the branch into a 4" long section and about a 14" long section. These we used to test the splitting ability of a couple of the blades by using the claw hammer to whack their spine like a splitting wedge through the wood. Both blades so readily split the 4" section that it rendered no particularly meaningful results. They both split it cleanly before the blade was hammered even about half-way into the shorter section.
  • A1 = split the wood of the longer section very vigorously. It readily kept the split well ahead of the cutting edge as the straight-grained wood was levered apart by its wedging action.
  • Busse Basic 5 = likewise split the wood fairly effectively, but it seemed not quite as well as the A1. When the Basic 5's spine (1/4" thick) had been hammered flush with the end of the section, the split was a measured 4" ahead of the cutting edge of the blade. It appeared to stay about that distance ahead of the edge, except where the grain of the wood took a mild curve and bound the blade a bit more tightly.
This morning I sharpened the Busse Basic 5 on my Spyderco Sharpmaker to restore the edge, then did a bit of retesting of it on a section of the dried branch I'd brought home for the purpose (i.e. same testing medium pre- and post-sharpening of the blade). It split the branch as well sharp as when it was dull. This is not surprising since the outer edges of the spine were the contact points while it was wedging apart the wood and the edge wasn't touching the wood, so the condition of the edge doesn't matter. After quarter-sectioning the wood, I took the Basic 5 and whittled heavily into the wood, again as if trying to hog off a lot of wood in a hurry to make the wood pointed. It did this very much better than when the edge was compromised, as one would expect it to do. A rough subjective estimation would place it about a 5-to-1 improvement.
So what does all this prove?? My observation is that it shows how important geometry (stock thickness, bevel shapes, belly & blade length) is to the CUTTING & SPLITTING abilities of the blade and how raw mass (plus some nominal geometry) influences the CHOPPING ability of the blade.
The other more important point perhaps, was summed up by my cohort in all this whack & whittle. He enthusiastically commented after we were finished how comments about some of these factors on numerous occasions were suddenly, starkly, EMPHATICALLY conveyed in a tactile manner that was much more visceral and comprehensive than all the talking & reading about them.
Bottom line: Spend as much time with knives in hand testing & checking blades as with your mouse in hand researching blades here on BFC and elsewhere online. :) That way you really develop YOUR OWN sense of not only what type of knife works for you, but come to understand in that tactile sense the subtle and not so subtle mechanics & reasons involved in why you prefer those blades.
RokJok :
Most people refer to this knife as the classic sharpened prybar, with an overly thick profile and and thus neither cuts or chops well, however your comments tend to run very positive on its cutting ability in general. Have you handled any other SRK's? Is yours just ground with a finer edge than normal?
... develop YOUR OWN sense of not only what type of knife works for you, but come to understand in that tactile sense the subtle and not so subtle mechanics & reasons involved in why you prefer those blades
I could not agree with this more. It is only by comparing various blades that you can begin to appreciate the true levels of performance and gain an understanding as to where it comes from.
Nice job.
-Cliff
Cliff,
I rebeveled my SRK to a 20 degree edge. It took along time even with dimond stones, but, was worth it. It does chop extremely well for its size and weight. It also whittles and cuts great now. The only problem I have with the knife is it's duability for baton work due to the rubber handle. If this knife was made with a different handle material I would love this knife.
Since I can not get by the rubber handle problem, I carry a Becker C/U 7.
I always enjoy reading your comments.
Thanks,
Geoff Massa
Originally posted by Cliff Stamp
RokJok :
Guess it must just kill you, Cliff, that someone actually likes an SRK. Why worry about what others say? Or are you the one saying this? People that repeat this tired line tend to pontificate on the superiority of other thicker knives at the same time, such as the Fallkniven A1.
This knife is 3/16ths of an inch thick. If that strikes you as a sharpened prybar, then you haven't done any real prying.
My SRK's cut very well, I have one "stock", and one that I likewise re-beveled. My altered one is at about 25 degrees, and it cuts great, but does tend to get damaged much easier than the "stock" SRK. The original profile is great for outdoors work, but the knife is a little light for chopping.
As an all-around knife that is light and easy to carry and is strong for survival purposes, it is just about perfect for me. This is a difficult balance to strike, and the SRK achieves it.
Cliff, Unfortunately I haven't handled any others and have in fact only used one of the two I got several years ago. The edge condition (e.g. no regrinding of the bevels) is factory original with a few sessions on a Sharpmaker model 203 being the only sharpening its seen. I would put the SRK in the sharpened prybar school of knifemaking (vs slicers out of skinny stock like my SAK or kitchen knives) based on the thickness of the SRK stock coupled with the low height of the primary saber grind. However, I would be much more hesitant to actually pry with the SRK than the 1/4" thick Busses in INFI due to the SRK's slightly thinner stock in less ductile (resilient?) steel.
I think the variable may be the difference in what I call "sharp" and what others define that term as being. Hence, an SRK that I think is sharp may be unacceptible to folks with more stringent definitions for that term. Since most of my blade usage centers around light chopping and whittling of softish green brushwood, my "sharp" will be much different than for instance people cutting soft tissue or trimming cables with their work knife. Sometimes too, when I call a knife sharp it is in relation to the other knives (or my shaky memory of their performance ;)) that are being used for the same jobs.
If a blade will shave hair from the back of my hand with a push stroke and/or slice cleanly into the edge of advertising flyers (sort of heavy, stiff, smooth, hard-finished paper) with no hesitancy or "catching" of the edge as it parts the paper, that's what I generally define as sharp. Other times I will try to slice off just the outermost layer or two of dead skin from a finger pad to judge relative sharpness of an edge. So if a knife edge feels like what I remember those sharp edges feeling like, I will likewise call the edge sharp, however erroneous that estimation might prove. My definition of a working edge loses the shaving test and a toothier feel becomes acceptable. IIRC others require flawless cutting of very light papers to call a blade sharp, which my blades would not do.
I am really starting to like my cold steel trailmaster it chops great and it cleans game very well,as for the edge mine is great,it still has the factory edge,I can clean rabbit and trout with it and ive already made a shelter that I slept in for 2 days and it held up great.So if I can clean game and make a shelter with it with no prob,imho ive got a great knife.
Geoff :
Yes, I had problems with the Kraton grips on CS knives as well. They basically fall apart with extended use.
Thanks.
Swede79 :
[SRK = sharpened prybar]
I have not used it, but that is in general why you go with sabre grinds, to increase lateral strength. When I made the above comment, I was thinking of posts specifically made by Joe Talmadge and Mike Swaim, two of the more knowledge people in regards to geometry and cutting ability in general. The one reference that stands out is the following :
http://www.knifeforums.com/ubbthrea...=&Board=UBB13&Number=33921&page=&view=&sb=&o=
However a simple search here will turn up many similar comments as well as on rec.knives .
Edge geometry plays a more critical role in cutting ability, and the edge geometry on the A1 can be much thinner and more acute due to the complete convex grind. Or on a more extreme level for example, I have many khukuris while being twice as thick as for example the Cold Steel Trailmaster, will easily out cut it significantly because of the difference in edge geometry.
RokJok, thanks for the additional details.
-Cliff
The edge on my SRK had to be 25 degrees plus out of the box. I eventually vised the thing and used a file to rough the edge down lower, then finished up at 20 degrees. If RokJok was able to use his Spyderco 203 with his out-of-the-box SRK, that means his SRK came out at a 20 degree edge, which means he got lucky (or I got particularly unlucky). Carbon V seems plenty durable at 20 degrees, so it's still a good use-and-abuse knife -- but now it actually cuts, too.
BTW, even at the original factory angle, my SRK shaved hair right out of the box.
Joe
I recently gave my Brother a SRK, he uses it to cut steel belted radial tires (he is the manager of a tire store). Out of the box it came with a very thick, but nicely polished and higly aligned edge. It would push cut through non binding materials like small diameter rope, cloth, etc, as well as absolutely filing the hair off my arm, it was very sharp. But is has a thick sabre grind and cut poorly in binding materials such as potatoes, thick cardboard, etc.
I really dislike the kraton handle, my brother loves it and doesn't like the micarta handles that I greatly prefer.
It is definetly a prybar though, not a knife optimized for slicing ability.
Chad
RokJok,
I didn't know where your test was going at first. Great final conclusion though. People need to find what works for them.
SRK, is a great knife for the money. No its not that great at anything but it is robust, carries a sharp edge, gives a reasonable grip and pays its way. Yes a little reprofiling makes it better at cutting and krayton gives really painful blisters if you do any extended work. But I often recommend it as a first knife to people who don't really know what they are going to use a fixed blade for. There are a whole lot of people out there who just don't know how useful a good knife can be. They also wince at paying over £$50 for a knife because they just don't know. If they do catch the "out in the wild" bug and want to carry a fixed blade to use then they have probably gained enough experience with the SRK to know what more they want from a knife. SRK's are a least easily available.
Knives as a pry bar. Often quoted, but rarely intended to be literal. My definition of a pry bar knife type is one that can pry open a stuck window, dig out a scapping, spinter wood, lift a concrete slab and is robust enough to take some human strenth abuse without additional mechanical advantage, such as a length of pipe, being applied. 1/4 inch stock blades and above. They just shouldn't snap, but then thats a much to do with how they were made in the first place. Fine edges on pry bar do get damaged fast as it goes with the territory.
GREENJACKET :
[SRK]
There is a lot to be said for this as many elements of knife design can only be determined by the user which can only come from experience. Chad's comments on grip preference being an obvious example, two very different reactions to the excat same handle. Now, this initial experimentation with the knife can be very telling on the blade as you try out various methods, see what it can and can't do, explore sharpening, differnet angles / hones etc. . So you are going to be putting a lot of wear into the knife, and you are probably going to hesitate doing this to a high end production or custom, so you simply won't learn as much.
With a few weeks experience with the SRK you are in a much better position to get the right high grade knife for you. The Becker CU/7 would also be a solid starting knife, not as robust as the SRK, but with better cutting performance. Ontario makes decent starting blades as well, but the QC there is so low I would not recommend them, as you don't want someones first experience with a fixed blade to be with an overhardened blade, underhardned tang etc. . This is probably the biggest cause of people having an aversion to prying, chopping, splitting etc., with knives.
-Cliff
I've always liked thin bladed knives. They are the best for cutting. But you just can't pry with them as either they flex or, if hard, snap. Its definately the case with less expensive knives that too hard they tend to snap even when the stock is on the thicker side. They are made hard to get that edge everyone wants.
Makers really do have to do their homework and monitor their heat treatment to stop hard steel from snapping from lateral stresses. Large manufacturers have tolerances that one can live with because its reflected in the price and backup. The reasons that I like medium manufacturers such as Chris Reeve is that they can go one step further and that the product can be reproduced if you were to loose the piece, but you pay for the additional expertise and care. However, it seems to me that not every medium manufacturer really justifies their higher prices as they shop out too much of the critical work, the heat treatment in particular. Design is one thing but its the steel and whats done with it is what counts. I'm not really a custom buyer, but if I was then I would go for a custom maker that loved playing about with steels first, design second and finish third. Custom knives made this way could be a bit of a gamble, as any steel could have a hidden fault, but at least there is a cahance to have something quite exceptional.
The reason for some thickness in a survival type knife is so that it doesn't break when used for more than just its sharp edge. Otherwise whats the point and no, extra weight for chopping per say is not a good reason on its own.
GREENJACKET :
Yes I feel much the same way. It is the propeties of the steel which allow a design to be functional and thus it is where the whole process begins. Plus when you work with steel, you obviously spend a lot of time experimenting with results and that is the proper mindset for developing an understanding of geometry.
Yes, if the chopping ability is low and you decide to get around this by just adding weight you have probably made a poor design choice. Chopping is very sensitive to balance and depends on the same geometry aspects as good cutting ability in general, so look at those aspects first. As for which way to go for balance, it depends on what you are doing. I have used light and fast bowies and much heavier ones. The light and fast ones work great in general cutting, very low fatigue, and are great in light brush work for the exact same reasons. However when you have to cut a decent sized pole you start to struggle. If I didn't know what I was going to be doing I would opt for the more blade heavy version as the greater fatigue it would cause for the light work, would not be as much of a problem as trying to use the light blade for heavy work. But that is not a realistic senario, you should be aware of your enviroment, what it takes to do what you need to be able to do. And as always, combinations of tools are always much stronger. A light and fast bowie and a small axe is much better than just a heavier bowie.
-Cliff
Rok Jok's test knives were all utility sized survival/wilderness knives. None are particularly heavy, except for the Busse BM which is really in its own catagory. At this size and weight they are never going to be great choppers. They should cope with most jobs which I think they all do reasonably well. I think a great test is: "am I still happy carrying this tool when two thirds up the hill?" (Should be asked when you are two thirds up the hill.)
As for sharp I think DMT green is fine, though I like mine polished keen when first setting out.
Better to be carrying a knife than not because you are still saving up for it.
...used to test the splitting ability of a couple of the blades by using the claw hammer to whack their spine like a splitting wedge through the wood.
I can't believe you pounded on the spine with a hammer! Not that these knives shouldn't take a little of this, but its certainly not a recommended procedure, even for this very splitting act, another log used as a hammer being much preferred!
Nice testing, though I think you should have brought all the knives up to the same level of sharpness before you started...
That's a valid point I'll try to remember for next time. Since we were supposedly checking the extent to which various blade geometries affect performance, having the blades at varying levels of sharpness introduced a second variable into the environment unnecessarily. I suppose equal sharpness should be an obvious condition, but I sure missed it when we initially went through the exercise. Thank you for the reminder.
Yeah, a log baton or wooden hammer would have been more forgiving on the blade spines when whacking on them. Somehow I missed that "kinder, gentler" thing that went around a while ago. I think I was out testing knives when it was proposed. ;)
GREENJACKET :
Essentially, I ask myself the same thing, would I really be wishing for another knife if I had to rely on this one.
As for the hammer thing while it is not a normal part of my daily useage, it is not something I would see as that extreme. While it might sound really brutal, take a carbon steel blade and see how much wood you can split with it using this method until it breaks, try something like a Cold Steel Red River for a low end estimate. Yes, it is a decent level of impact, but tempered tool steels are not that fragile, consider what they are used for in industry. The blades used in the above are for the most part aimed at the ultra heavy use market, how sensible is it for them to be more brittle than a plain carbon steel butcher knife.
The only real concern I would have about hitting a knife with a hammer is beating off the coating, or on differentially tempered knives as the spine is likely to get impacted. If I was doing it a lot I would get the blade periodically stress relieved. I usually don't, simply because I don't carry a hammer with me, but if such a blade fell apart while I was splitting a dozen or so pieces of wood in such a manner I would not be impressed, as quite simply there is no need for it to happen given the right steel and heat treatment.
For the stainless steel blades this will be a significant problem due to the inherently much lower impact toughness especially at ~60 RC. But not all knives are made from stainless, and fortunately they don't then all have the same restrictions on use. And even for those stainless blades, at that level of thickness used in such knives, ~1/4", they are still not going to fall apart that rapidly.
-Cliff
I was also surprised at the metal on metal hammering thing. I've seen a number of hammers carrying warnings about wearing eye protection when hammering metal due to possible chipping (perhaps of the hammer in this case if was cheap?). I normally place a piece of wood between the hammer and object-to-be-hammered in these scenarios.
Cliff - out of interest, where/how do you "Get a knife destressd"? Sounds facinating!
Best regards
Kallisti.
Kallisti, you get the knife tempered at 25F less than the original temper, this acts to relieve fatigue stress.
-Cliff
