Busse finish survey: Black or Tan crinkle finish?
Hi guys, Doing a little survey: Busse regular finish prefer Black or Tan finish? I personally go with Tan but a lot of guys seem to order the black finish. Thanks
Tan, tan, tan!!! Then get yourself one in black and double cut.
You'll need several to choose from...really;)
Double Cut...DC....beadblasted!!! :eek:
DC Rocks! :D
I think the black looks nicer than the tan but I've heard that the tan is a little tougher than the black. Don't know this for sure cause I don't like the looks of tan so unless I stumble upon a SFNO in tan I most likely won't be buying a tan coated Busse.
Stay Strong & No Regrets!
What do Roy Orbison, Marilyn Manson, Neo, vampires, ninjas, JBT's, Black Panthers, mimes, and people into goth, D&D & S&M all have in common?
I'll go with tan.
I like the tan a lot more. Something about a black blade just bugs me.
That said, I prefer no coating at all. INFI is rust resistant enough to do without it.
I would usually choose black instead of tan, although I do like the tan finish with a tan handle. I have not used one with a tan finish enough to comment on the durability of the finish, but I find the black crinkle finish to be very durable - with a lot of use it eventually gets smooth. I do like the satin finish also.
Gene
The old smooth "metallic ceramic" black coating flaked off quite a bit.
The black crinkle coat adheres better, but still chips off, though usually very small chips and in my experience usually near the tip. Ditto for the green crinkle.
That tan coating is, I think, totally different stuff. Many of mine are coated with this and so far no chipping or flaking. If you notice, the tan is not a crinkle coat at all--more like beads fused together. It definitely has greater wear resistance, and I think its adhesive properties are way better. And just a guess, but it might have more elasticity as well as I suspect the reason for the black coating chipping off has something to do with becoming brittle. Or it could be that the blades weren't thoroughly stripped before coating, and a little oil or other residue was still on part of the blade when it was coated.
So color preferences aside, the tan coating is the highest performing coating so far.
Hi, Looks like the tan finish is ahead by a few votes but overall seems everyone prefer satin finish as first choice including myself! Hope Jerry reads this thread ;)
