LOL! Very good, Bro!
I heard FB is now a Grinder!! :0
I hear from those in-the-know, that a forged blade is superior to Stock Removal.
Out into the light...back to from wherever it came.... :grumpy:
Forging ceased to be an inherently superior method of making a knife around the time industrialization gave us steel mills that could produce high purity steel. It's a whole lot more romantic than stock removal though, and you can do stuff with damascus and patterns that's impossible with stock removal alone.
that is true. But unless I am mistaken, I think you can even get Damascus billets, that are factory produced, and use stock removal on them (probably much more expensive that way).
The big difference is that a forged steel does not go through a heat treat after forging, the forging process is the heat treat, so IMO, a properly HT's knife from stock removal can be superior to a forged one, especially if the HT is done like Busses are.
Yeah, but with forging you can further manipulate the pattern and make it stretch and curve to match the shape of the blade, it's another creative outlet
I was nodding along with you right up till hereAll knifemakers will do a proper heat treat after forging. Generally after the blade profile is forged the smith gives it a normalizing and maybe anneals it. Then it's off to be stock removed
Once the blade is cleaned up and ground to finished shape it goes through a few normalize cycles to relieve the stress incured during forging and stock removal. After all that then it's treated just like any other steel, harden then temper to taste. So, for all that extra work involved you end up with a blade that (if you're good and didn't mess something up during forging) at best will be as good as a stock removal one with the same steel and HT.
Yes, yes you can.that is true. But unless I am mistaken, I think you can even get Damascus billets, that are factory produced, and use stock removal on them (probably much more expensive that way).
