tiogatires
- Feb 6, 2007
I have searched this topic and found some great information. Some of these other posts (to which I give credit for this mod method) gave me the nudge to try it myself. Here are my results:
1). Needs yo self a NMSFNO (Thanks to RoNNiE - This things badass!) :thumbup:
2). Tape it up with blue painters tape. I used about 10 layers per side and about five on the edge and spine to add width/girth to the blade. Doing this will give your NMSFNO alittle wiggle room, not too much - but just enought to get the blade in and out once finished with the mod.
3). Remove the screw set on the bottom of the large Spec Ops sheath and use it for something else. You wont be putting this back in or the knife wont fit all the way down into the sheath properly. If this happens, the retention snap strap wont line up correctly with the scales and it'll be a beatch to snap shut. You really dont need it anyways. The plastic/kydex liner isn't coming out of the sheath unless you want it to.
4). Pull out the kydex/plastic liner from the sheath and preheat the oven to 350F. I usually place the liner on a cooke sheet so I don't have grill marks in it.
5). Leave it in the oven for about a minute..... SERIOUSLY!!!! 60 seconds and check. If it's pliable, pull it out and shove yer knife in it slowely (you know the routine)... I use my Wife's oven mit to hold the liner whilst performing this action.... That Sheezit is hot! Once the blade is in the liner to your liking, place in fridge next to cookies.... Don't eat those bastids....or the kids will cut you with your own blade...
6). After the liner has cooled COMPLETELY, pull out yer blade and remove the tape. Check yer fittin. If you don'd like the way it fits, repeat steps 1 - 5 and try it again. Put the knife into the liner and shove it back into the sheath...
7). Viola! Mine has a decent fit and it works as expected. I've done this with a Skinny ASH as well just with the smaller Spec Ops sheath and it came out pretty good too.
Hope this helps out with others who are verbally impaired such as myself. I needed to see it.... Well, here ye go...
