bigtree31:
<font face="Verdana, Arial" size="2">OK which is tougher, stronger, and better made?</font>
The Strider models I have seen have a lot of full stock steel in the blades, this makes them very strong. For example, here are a PAB and WB :
http://www.physics.mun.ca/~sstamp/images/pab_wb.jpg
Note that there much of the blade width that has the full 1/4" stock thickness. Compare this with for example a Battle Mistress :
http://www.physics.mun.ca/~sstamp/images/bm-side.jpg
Here there is a full taper from the spine to the edge as well as a significantly greater taper to the edge than as compared to the PAB and WB.
I would assume based on this that the Striders are stronger. However I have yet to find something that requires a level of strength beyond what the Busse has and have been trying for some time.
There is a large amount of cutting ability lost by leaving all that steel there which gives the Busse blades in general a very significant advantage in regards to the time and effort required in cutting chores.
The Busse blades are significantly tougher than the Striders. This is simply due to the difference in steels used. While ATS-34 is a very strong, wear resistant steel, it is not overly tough. I have chipped out two Striders (both WB's) doing things that did not chip out the Busse.
However these are fairly high stress tasks, you have to be hitting/twisting the knife in contact with hardened metal or something similar like rock. I have not chipped out a Strider on wood and such and have done a lot of chopping.
I still have to finish up the review of the WB and and just starting working with the PAB so I still have some work to do. I intend to do a lot of work and thus better quantify such things as exactly how much more (or less) damage will the blades take while chopping bone, wire, digging etc. .
One other thing which is important to me, the Strider cord wrap is significantly more secure than the old style grip on the BM above. I have not used one of the new BM but I would be surprised if it was more secure than the Strider wrap.
-Cliff
