Busse Web site
What's up with the Busse web site??? Message says page can't be displayed. Revamping it to show the new models???:D :D
Happiness is putting the wet stuff on the red stuff
Still nada. SwampRat is fine but can't find Busse by any means. Hmmmmmm
Was it something I said???
:footinmou
Maybe Jerry didn't like that reverse auction that he lost:D :D
Nope. No luck. Even tried rebooting. Experiencing some kind of anomaly here. Will wait to see if it clears itself up
No soup for you!
Try clearing out your web cache. Sometimes that can cause problems.
If you're using Internet Explorer, go to Tools->Internet Options and then click the Delete Files button... it clears out the temporary internet folder. If you use AOL it's totally different. Don't click Delete Cookies by mistake unless you know what you're doing!
If that doesn't work, try putting http://64.176.151.242 as the url. That's the ip address for the Busse website. If your ISP is having DNS lookup problems, you may not be able to reach the site by using www.bussecombat.com
If that doesn't work... maybe there's a link down between you and their server, and you'll just have to wait it out.
good luck!
your friendly neighborhood unix geek.
You can find out of there's a link down by bringing up DOS Prompt or the command prompt or whatever in the accessories (provided you're using windows) and typing in "tracert bussecombat.com"
If it finds the site, then, well, it's probably a problem on your end and worth working at to correct. If not . . . how patient are you? :)
Hey Stripey, cleared out the temp internet folder as you suggested and every thing is now fine. I usually clean it out quite regularly and was suprised how much was in there. Thank you and the others for the imput.
Bill, KX1A
Happiness is putting the wet stuff on the red stuff.
