- Aug 31, 2002
All three of my kukris have problems with the buttcap either being loose or having a gap. Using the infromation on this forum I peened one of them but it did not last. I've been trying to peen the other two today and have had ZERO luck. I've mostly been hitting the little dot of exposed tang at a roughly 45 degree angle while working my way in a circle. I've tried rapid light taps, I've tried heavier hits (as heavy as I can without missing), not working. My Chitlangi has a huge gap between butcap and handle but will not close at all, which I though may be due to laha being in between the two. So I got my BAS out, which has a flush fitting buttcap that can be turned very easily. I again could not get it to tighten. Does anyone have any tips? Any potential problems that you guys can spot? How hard do I need to be hitting and how long should it take to peen a buttcap?
