Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
what about the slick surface to take place of the water?
Mike that's IdeaDan, have you tried simply making some shavings off a scented candle and seeing if it'll dissolve in some veggie oil? Heat it up in a cup in a pan of hot water. That might work for you.
The "berry smell" (more like apple to me) of butyl acetate will only smell like that in low concentrations. After that, it just smells like the solvent. If you go out and buy some, just buy a small amount to try.
Another thing to try is just a drop or two of an "essential oil" from some new age crystal power shoppe. That way you could piss into patchouli one week, vanilla the next. Just think, nice little clouds of hibiscus rising up to complete that relaxing sensation! LOL
BTW, any kind of silicone oil will work for this application, too, and it won't go rancid.
Dan
If you need it pure:
I looked it up in Sigma
Thanks Mike..Dan, I have my doubts about the complete biodegradability of silicone oils. Partially, perhaps, but not completely. Considering the small amounts necessary to coat the surface (a couple drops), it might not present a problem to your septic field. That said, I can't answer you with any certainty.
Regarding the butyl acetate amount...I agree that you should buy a very small amount, especially at first to experiment with. It shouldn't take more than a few drops per charge to get the effect you seek.
I'll mention again testing your idea with an essential oil used in aroma therapy. It'll be much cheaper to experiment with than buying butyl acetate from a chemical supplier, and should be more readily available in some storefront in your area.
BTW, you could always try this handydandy modern-day social-acceptabilty product: http://www.justadrop.net/![]()
Dan
No other cheap sources known to me i'm afraid.
Now that i know the application, I would use fitzo's suggestion for a DIY project.
The oil floats on the water in a trap and seals odour.
The BA smells nice.
I would give it a try with mineral oil and
any type of essential oil - from the local hippie/health shops should do the trick.
When you connect this to drain, use plastic pipe if allowable by code.
the Uric acid will destroy steel.
If you use HT oil & aroma therapy, you can pee & quench at the same time!!:barf::barf:
[sorry....I just had to...]
Interesting concept,Dan. I have a camper that has seen its last camping trip. I wonder if I can set up the toilet as a shop fixture.Never thought about it but I'll have to look at it a little closer.
ok I see...I mean, what stops it from getting a layer of urine on the surface of the urinal, where normally it gets washed from the water.
