- May 17, 2002
I recently ordered a sheet of CF-pattern Concealex and a sheet of black Kydex, plus Chicago screws. The guy I ordered from threw in a smaller piece of grey Kydex as well.
So I started making a Concealex belt sheath for my customized EKI Mini-CQC-7B, pancake style...what can I say, it works well. It doesn't take nearly as long as I suspected - and it's fun.
Well I did screw up my first attempt, but the second one worked out nicely. It sure as hell doesn't look anywhere near as clean and flawless as the ones the pros make and the knife does have some play in the sheath, but it works. Used two strips of high-quality nylon webbing to form belt loops that fit the belt I usually wear perfectly. Very sturdy construction too.
Then I went on to make a single-piece neck sheath for my Benchmade Mini-Pika - that one even looks reasonably nice. I also made a sheath for a custom a friend made for me about two years ago, always wanted to carry it, always wanted to start making my own sheath for it, just never got around to do so - until this weekend. Now it's got a black Kydex IWB scabbard (with a J-hook). The knife locks securely into the sheath, when you draw it you just have to press down with your thumb on the top of the sheath, I incorporated a "thumb ramp" to facilitate this.
Works very well considering that I'm a beginner, if I may say so myself.
I didn't even have to use a Kydex press.
Bottom line: I will still ask a sheath maker to build sheaths around more expensive customs I buy (simply because they look a lot better and work a bit better), but I will continue to make my own sheaths for more inexpensive knives. For example, I would never order a neck sheath for my Mini-Pika, simply because the sheath would cost as much as the folder itself and I rarely carry folders that way anyway, but the neck sheath for it was a nice evening project.
