... can an old leather belt be used?
The Strop Block has been my go-to strop for many years now, and I have never reloaded it and never cleaned it. The surface, as I write this post, is as pristine and green as the day I bought it. It is not magic or secret. It's just the quality of construction and the way they apply the compound. When it starts to load (turn black on the surface), you dip your finger in olive oil and rub fresh compound to the surface, and it is refreshed and ready to use again. All of the strops I have loaded myself have needed, at one point or another, to be scraped or otherwise cleaned, and reloaded. Good green compound, like Bark River for example, comes in a hard, waxy block. It's hard to work, it chalks up and clumps like drying clay. It separates from the strop if you try to apply it too thick. If you apply it thin, it eventually needs to be replaced.
With the Strop Block, the compound stays on the strop and doesn't come off. It isn't magic or some big secret -- it's just the way they load it, which you could replicate yourself because KnivesPlus explains the entire process on their website (see below). But I'm happy to pay someone $23 to do it for me because it's a little more involving than rubbing a block of green compound on leather. Plus it's a high-quality, well-made strop, even without the pre-loaded compound, and will probably last a lifetime for the average knife sharpener. I've had mine for years and used it on hundreds of knives. And I spent more than $23 eating at Buffalo Wild Wings Thursday night. I'll let Knives Plus explain their process better than I could (below). It's just a different loading process, but one I personally don't feel is worth doing myself, and it's what makes the Strop Block different from any other strop you can buy. That's why I highly recommend it.
from KnivesPlus website said:"Chaps are the soft leather that Cowboys wear over their Levi's to keep the Mesquite bush thorns and prickly pear cactus from eating their legs up. It's soft but tough.
We use contact cement to glue this leather down to a 2 1/2" X 8" (approximately) particle board base. When the glue is dry, we raise the leather's nap by scraping with a razor blade to allow the polish to penetrate the leather and give it a "bite" when used.
Next, we melt down a high chrome rouge in olive oil until it is the consistency of thick vasoline. We smear and work this preparation into the leather surface with a hard rolled shop rag until the surface of the strop is thoroughly saturated and coated. Then we let the polish sink in and set for two days under low heat.
Finally, we rescrape the surface of the strop to remove excess polish and reset the nap. We run the edges of the base on a Burr King grinder to smooth and round the sides for comfortable use, and remove the green polish that gets on everything.
Remember these strops are hand made and are not the prettiest things in the world. They are also subject to the availability of the right piece of chap leather, and making them depends on what materials are available.
We use particle board base material. Width may vary from to 2"-2 1/2" and length may vary from 7"-8". Leather color may vary from cream color to dark brown which will affect the color of the finished product. Each strop is hand checked for "nap and grab" before being packaged."
+1 for the Knives Plus Strop Block. Pasting here from a previous thread in anticipation of responses -- "It's just a gimmick, it's too expensive, you can make one just as good for nearly free, etc.":
Quote Originally Posted by from KnivesPlus website
Soft? Ever see a soft barber strop? On the other hand, I'll bet it makes great convex edges.
Stitchawl
10-12oz veg tan, dampened, rolled with marble rolling pin until it is the thickness of 5-6 oz leather(thinner if you have the muscle), cut to desired size, glue to wood paddle, clean & treat with good leather conditioner once a year and use for the rest of your life. your kids and maybe grandkids lives too.
uh yuh Stitch...some things are worth repeating a time or two.What a great idea! ROTFL!
At this point, I am considering buying Stitchawl a Strop Block so he can try it first... but I'm half worried he'll just burn the package without opening it.
Seriously though, Stitch, the Strop Block is genuinely a good, high-quality strop.
