Yes, that is what rigidized does.
In most smaller forges, the wool blanket can just be covered with the refractory.
 I usually put a waterier coat of satanite on first and let it dry, then the regular thickness refractory coating is applied. I use rubber gloved hands to apply the refractory. Long paint stir sticks can be used to smooth areas that need a touch-up.
Pouring a liner works very well if you can make the mold from something like PVC pipe. You want to cast a liner about 1" thick.
Cut the inner core into three sections and place them around something to keep in place (a fat pool noodle works great). Use electrical tape on the ends to hold together.
The outer shell of the mold can be two pieces of PVC pipe and taped together with duck tape.  Place the two shells over each other with the bottom on some clay or putty, and pour about an inch of refractory down the void. This will keep the two mold pieces properly spaces. Adjust the two pieces to be evenly spaced.(temporary  wooden spacers help) and let that bottom seal cure a while, then pour the mold full to the top.
After the refractory has cured, remove the inner core and three pieces of mold, then remove the outer shell. Let cure for a week, then wrap with the wool and enclose in the forge shell. Sheet metal makes a fine shell for a cast liner forge. Firing a cast liner with the burner to finish curing it is a long slow process, but once fired it will be very robust.
Once heat soaked in use for forging, the chamber will stay evenly heated quite well. Cast liners take a lot longer to fully soak. About 15-30 minutes is normal, depending on the thickness and chamber size.
