As UffDa said, you have many options. Just depends on what you want to do. If you are in an area that antennas are taboo, then a stealth run of #18 or 20 wire into a tree will be nearly invisible and will still work fine. You could probably find a used MFJ or similar antenna tuner that would work just fine for what you're asking for. In that case, you could just connect the long wire to one side of the tuner, and connect the ground side to some wires laid on the ground as a make-shift counterpoise. You could transmit through this. If the wire goes mostly vertical, it will work well as both a transmit and receive antenna. If you want to use it on 10M, then it only needs to be about 1/4 wave long - about 7 or 8 feet. Make it a little longer for 15 or 20M, and longer yet for 40/80M. For 80m, 1/4 wave is about 66 feet, and that would be a great length for 80m but might not be realistic at your location, not sure. If all you can do is a long wire, then get as much wire as high off the ground as you can. Counterpoise still applies.
Some folks also put wires in their attic if stealth is key, or use their gutters as UffDa said, or any number of other options (flagpoles, etc.).
And I'd agree, get up to General class (or Extra) and have many more options. Its relatively easy and the payoff is good.
PM or email me if you like - ham radio is a big part of my life, in fact if you get on the air soon we can have a QSO from a few interesting spots
