- Sep 19, 2009
I just tried the trick, over the last couple of days, of leaving a Case knife half open to soften the snap of one of the blades. It worked. What exactly did I just do?
On farm implements we have some parts we call spring steel - under pressure it will give, but not break, and then snap back into place. (I imagine similar to the leaf or coil springs on a car or truck). I'm assuming the backspring on a knife operates under the same principle. I don't know if it's the composition of the steel, or the heat treating, or a combination that gives it its "springiness", but would I be doing any permanent damage to a knife by doing what I just did? And what exactly did I just do - rearrange the molecules of the steel? Weaken the temper? And not that I would ever do this, but what if you forgot and left a knife in this half open position for a month or two? Would you end up with a knife with absolutely no snap at all? Is this procedure progressive and time dependent?
Sorry if these sound like stupid questions, but they are honest ones.
Just curious.
