StuntDouble
- Apr 26, 2004
Ok, so the other day I was driving to work, when all of a sudden my 95 Jeep Grand Cherokee just cuts off. I turn the key and it'll turn over, but not start. So I get it towed back to my old apartment, turn the key again, and listen for the fuel pump to run, which it doesn't. So, I tear everything down, remove the fuel pump, then get the bright idea to try checking the fuses. Switched the ABS system fuse with the fuel pump fuse, voila!. Fuel pump runs when the ignition is turned on. Unfortunately, I had taken it out of the canister, and in doing so, broke a piece that held it in. So no putting it back the way it was. No worries, I ordered an inline fuel pump, and performed the Swampy Bypass, which pretty much just means putting the fuel pump on the outside of the tank. Got everything hooked up, got a new fuse, turn the key, and the pump ran. Tried to start the Jeep, and all it would do is crank. We checked and rechecked everything, but had no luck. My friend pulled a plug and held it against the block, but it doesn't look like it's sparking at all. So, we're thinking, maybe the distributor cap, rotor, ignition coil, or ignition module have screwed up.
Anybody have any ideas?
