- Feb 15, 2009
One big frustration in fitting up a folder is the stop position. A little bit too much and you have lock rock, or a little wear does the same. The stop pins have been round and allow no adjustments. Problem solved: stop pin that is CAM shaped. You fit up the knife as usual, then can fine tune for early or deeper lock up. You can also adjust for wear or personal taste later on. All my folders now have this as a standard feature, have fit up about 200 so far. I will also make these available for other makers. We can custom make different sizes and USA Knife Maker (http://www.usaknifemaker.com/) carries them.
