Cougar Allen
Buccaneer (ret.)
- Oct 9, 1998
The newly reissued Camillus Becker Campanion is a knife designed for the hunter, wilderness camper/survivalist, soldier, who wants one knife to do everything.
The blade is 5 1/8" (13cm) long to the plunge cut, .225" (5.72mm) thick, and 1 5/8" (41mm) wide. The grind line is 1" (25.4mm) from the edge. The blade is 0170-6C carbon steel. It came with a good shaving edge if anybody cares, .063" (1.60mm) thick just behind the edge. The scale handle is fat, 1.100" (28mm) thick in the middle, and made of Gv6h, which is a glass-filled nylon but it's not like zytel at all -- zytel is only 10-14% glass; this stuff is 60% glass. It's very hard and rings like metal when I tap it with a fingernail -- feels like smooth metal except it isn't cold.
The blade has a rough sandblasted finish under the black epoxy. The handle looks lightly frosted but feels smooth; it relies on shape rather than texture for secure grip. It's nicely rounded and swells a little in the middle; it's not at all slab-like as you might think from the picture. The grind lines are not quite symmetrical and the tang isn't flush with the handle scales; it bulges out past the scales a little on the finger side. The scales are held on by three allen-head bolts; you could take them off to renew the baked-on coating when it gets worn.
The ambidextrous sheath is made of .125" kydex and retention is secure; it takes a good strong tug to get it to release. There's a strap for additional retention but there's no need for it IMHO. The webbing belt loop could fit a belt 4" (10cm) wide and it has a polymer buckle to fit it to the kinds of belts human beings normally wear. There are slots and eyelets so you could strap it to your leg or horizontally to your belt, to a pack, etc.
It's one seriously ugly knife and the sheath matches it well -- it's not a prit-ty knife; it looks utilarian, massive, even brutal. The Campanion is not made to hang on a wall; it's made to use.
It feels good in my (large) hand, so good it's hard to put down. I think I could use it all day and not get blisters. It's heavy for a 5" knife but not heavy for a chopping tool. Balance is right on the forefinger.
The wide thick blade is heavy enough for serious chopping and yet thin enough at the edge for good whittling. It chops like a hatchet and whittles like a pocketknife. The first thing I did was to chop and whittle at a pine 2x4 and the performance impressed me -- it chops great, whittles great, and feels great while you're doing it.
The pommel is well designed for hammering. Hammering with the spine wouldn't work very well; the handle isn't shaped for comfortable grip upside-down.
For fighting purposes, it's heavy but ergonomics is great -- again, the handle isn't designed for an edge-up grip but it works in hammer, saber, and reverse grips and transitions well between forward and reverse grips.
There doesn't seem much point in testing it for prying because it's so massive nobody human could break the thing -- and the point is not weak either. I'm going to try chopping some mild steel pipe just to make sure the edge doesn't chip ... I don't expect it will, of course, but I feel I have to do something more than chop and cut soft wood with it -- this knife just cries out for heavy use.
Looking back over what I've written so far I don't think I've adequately conveyed how impressed I am with the Campanion. Until now I've had serious doubts about the whole idea of chopping wood with a 5' knife -- no more! This thing really chops! And it cuts too! And it feels good! Although it's very heavy for a 5' knife it's not at all heavy for a chopping tool, and it's comfortable to carry on the belt, unlike longer knives and hatchets.
-Cougar :{)
